Trouble with Mice on my SOYO 4SA2
Reply 20 of 24, by maxtherabbit
Tiido wrote on 2021-10-17, 23:56:
It made the most sense to me, one has pins going 12345 6789 on DB9 end, and other 13579 2468, one is sequential, other is staggered... Easy to tell when you lift back the shroud on the DB9 side and that's where the naming came from.
Yes, but the ambiguity comes from the fact that the opposite is true if you consider the pin numbering of the Dupont header
Reply 21 of 24, by weedeewee
maxtherabbit wrote on 2021-10-18, 01:00:
^^^ This exactly 🤣
Do not ask Why !
Reply 22 of 24, by Tiido
The dupont header is visually same on both sides and one isn't gonna determine anything there without starting to measure stuff (though sometimes you can see the fat trace going to middle of the header), so it wasn't even a consideration as far as naming went, but the DB9 end is easily visible without starting to measure anything and it made sense. Sequential or staggered wires attached to the connector.
Reply 23 of 24, by Vipersan
I'm not getting caught like that again...and priced up the bits I'd need to make a second socket/interface for an serial mouse on the Soyo mobo ..or indeed any other mobo that used this non standard older config..
The price for the parts was about £10 with the shrouds and sockets etc..but in the search process I found this..
So grabbed one...
https://www.ebay.co.uk/itm/352194088184?hash= … zwAAOSwbdpWYr9f
I guess I will just use a convertional backplate port and connect in line with the mouse externally ...and should make conversion easy... using short dupont jumper leads.
rgds
VS
Reply 24 of 24, by Eimer
I have the same board and the same issue. I don't have a single cable that works.....
