First post, by -KRRU-Dominus
Star Trek: Starfleet Academy - GOG/Steam/CD-Version "DVD movie upgrade pack" (includes DVD Version "unofficial Windows 10 upgrade patch")
Release V1.0a - 17.06.2021 (last update of this post: 03.04.2023)
Compiled and tested by -KRRU-Dominus
The real work did gulikoza & dege (Thank you for your outstanding work!)
IF YOU DON´T OWN THE CD- or DVD-VERSION YOU HAVE TO BUY THE CD-VERSION FROM GOG (not STEAM) FIRST!
https://www.gog.com/game/star_trek_starfleet_academy
How to install:
- Download and install the K-Lite Codec Pack (Basic) from https://codecguide.com/download_kl.htm
- Install Starfleet Academy GOG or original CD-Version (Steam-Release does not work with addon)
- Copy the content of this zip-archive to your installation directory (overwrite all files)
- OPTIONAL: Download and install latest versions of dgVoodoo2 (http://dege.fw.hu/)
- OPTIONAL: Use dgVoodooCpl.exe to configure your graphics settings to your liking (resolution, antialiasing, anisotropic filtering); default settings (1920*1080) should work fine for most people
- Run sfad3d.exe (sfa.exe is NOT testet, but should work for software rendering)
- Enjoy the videos in 480p (DVD-Quality)
Known Issues:
- If you press "View Intro" or create a custom mission you get message "Please insert CD1" - not really worth looking into it
- Subtitles are no longer working after the upgrade (the DVD version does not and never did support the subtitles from the original CD .mve format that are still included)
- The "Starfield issue" (graphical glitch when moving in space) when playing in resolutions other than 640x480. More info can be found here: Graphic Issues in Starfleet Academy
Detailed information can be found in the included readme.
Downloadlink 1: https://tinyurl.com/tu6tdtsp
Downloadlink 2: https://mega.nz/file/yOQDFarJ#Ea82sREv0jvi6BX … qG4qREX_-ZUs2s4
Star Trek: Starfleet Academy - Chekov´s Lost Missions (Addon) --- Compatibility patch for Starfleet Academy (DVD-Edition)
Part of the installation guide was heavily inspired by Ben Trube. Thanks for the groundwork!
https://bentrubewriter.com/2015/05/12/agfv-st … t-missions-gog/
Where do you get the addon?
It´s abandonware. Duckduckgo it.
It has never been released digitally (nor has the DVD-Edition), but the addon is available on ebay and other locations.
You will need to get your hands on one to install it or else this compatibility patch is useless.
Since I own the retail version of the DVD-Edition and the addon I have contacted GOG if they can/want to include/release it. We will see...
Background:
In 1998 Interplay released an addon to Starfleet Academy (Checkov´s Lost Missions aka CD6) that was originally simply cut from the game (hence "CD6").
Unfortunately it was not included in the 1998 DVD-release of Starfleet Academy and never got a DVD-Upgrade.
Even worse: Since the original DVD-Version of Starfleet Academy plays only MPEG2-videos using the obsolete MCI interface (and no "Interplay MVE" videos from the CD-Version), the game crashes when you try loading an addon-mission. So the addon was not useable with the DVD-Edition. The same is true if you have applied the unofficial Windows 10 upgrade patch for the DVD-Edition. So here this compatibility patch comes into play.
How to install? --- it´s a bit complicated but doable 😉
1) You have the GOG or original CD-Version (Steam release does not work; thx@davidgcg)
- Download and install the Star Trek: Starfleet Academy - GOG/Steam/CD-Version "DVD movie upgrade pack" above
- Rename the installation folder and add .SFA
- Insert the Chekov´s Lost Missions (Addon) CD or ISO
- Copy the the “m” video folders from the movies sub-folder on the Addon disk to the movies sub-folder in your renamend installation folder. These should be m03, m04, m10, m11, m24, m25 and m27. DON´t copy g00.
- Copy the contents of the sounds sub-folder on the Chekov disk to your installation’s sounds sub-folder. Again this will be m03, m04, m10, m11, m24, m25 and m27.
- Install the Addon (run setup.exe in folder setup). If it won´t install rightclick -> Properties, then the Compatibility tab. Run in Windows 98 / Windows Me mode and Run as Administrator. The Addon will now be installed into the original installation folder but will overwrite nothing, since we did rename the folder before
- Rename the Addon folder to .ADDON, and rename the .SFA-installation folder back to the original folder name
- Rename data.dat in your installation folder to data.dat.old. Copy the data.dat from the Addon install folder (.ADDON) into your original install folder. Copy ONLY the data.dat file. Do not overwrite the EXE files or any other files.
- OPTIONAL: Delete the .ADDON folder
- Copy the contents of this patch into your movies folder in your installation directory and overwrite all files
2) You have Starfleet Academy DVD-Version:
- Install Starfleet Academy DVD-Version
- Download and install the Star Trek: Starfleet Academy - DVD Version --- "unofficial Windows 10 upgrade patch"
-----> Download: Star Trek: Starfleet Academy (DVD-Edition) - Windows 10 Upgrade Patch
- Copy the contents of this patch into your folder in your installation directory and overwrite all files
VERY IMPORTANT NOTICE:
There are two versions of the addon floating around AFAIK:
- One is dated 15.04.1998 and the data.dat has a file size of 48615 KB. This version is NOT working with the DVD-Version - it seems to be a german release.
- One is dated 20.03.1998 and the data.dat has a file size of 47699 KB. This is the one you want.
Downloadlink 1: https://tinyurl.com/2at8er82
Downloadlink 2: https://mega.nz/file/fSI3BYpB#Sp9rdcSWw9l2ArL … uhYoIXV-Ne3cQRs
Please let me know if it works for you and discuss any issues here.
Reply 1 of 12, by feda
Doesn't work. Failure initializing input devices. I'm using the original CD version. It was working before your patch, btw.
Edit: deleting dgvoodoo's dll files fixed the error message, but the videos are black even in software mode.
Now I've noticed that the original unpatched version also isn't working right in d3d mode, with or without dgvoodoo.
Edit 2: Finally tried this "upgrade" on the GOG version. It works, but the videos take AGES to load. Ironically they look worse than the CD version. The letterbox is not centered, the bars are gray instead of black, the image is less sharp and it just looks like a low-quality DVD, whereas the CD version has that proper old 256-color FMV look.
The GOG version comes with a custom ddraw.dll that enables anti-aliasing and anisotropy, so it looks pretty good without any tinkering.
Dgvoodoo works too, but the starfield leaves lines on screen above 640x480.
Save yourself the trouble, stick with GOG.
Reply 2 of 12, by -KRRU-Dominus
feda wrote on 2021-09-17, 21:04:
Interesting, I have the CD Version (German & English) as well as the DVD Version. All three version worked with the patch on my setup.
I tested the patch on an Win10/NVidia GPU Laptop & Win10/AMD GPU PC.
Did you mean unpatched, as no V1.15 installed (didn´t try that). Or did you mean, without my patch/dgvoodoo. Have you tried the latest version of dgvoodoo?
Well, you clearly did not read my HOW TO / Readme which is included in the patch:
Configuration:
dxmci:
%WINDIR%\system32\rundll32.exe .\dxmci.dll,configure (from cmd.exe; launch from installation folder)
- VMR9 Renderer: works, but long video loading times
Leave "Use VMR9" and "Force Mpeg2Dec" unchecked!
That should fix your problems - but no guarantees here, since there are dozens of things that can go wrong.
Your problems with the DVD Version videos may be fixed too, if you configure your K-Lite and dxmci properly. They are no real 480p SD-DVD-Quality, but way better than the CD Version (objectively, not subjectively 😉, but feel free to stick to the videos from the CD version. Small hint: In the foreseeable future, there will be an HD Upgrade pack available, that will need the DVD-Version/Patch.
You should be able to fix the starfields if you switch to "ATI Radeon 8500" emulation, at least that worked for me. EDIT: Does not fix the starfields, only alpha blending / transparency on nebulars.
Thanks for demeaning my hours of work, much apprechiated.
Reply 3 of 12, by RetroGamer4Ever
My Uncle Brad worked on the SNES port for Starfleet Academy. It's the worst version of the game, as it's quasi-3D graphics are pretty bad, but it has a special place in my heart.
Reply 4 of 12, by feda
-KRRU-Dominus wrote on 2021-10-18, 18:56:
Actually, I followed your readme to the letter and it does not work with the CD version.
Anyhow, none of this matters.
I'm happily playing the GoG version which has OBJECTIVELY better looking videos.
RetroGamer4Ever wrote on 2021-10-18, 19:13:
There was no SNES port of Starfleet Academy. What you mean is Star Trek: Starfleet Academy – Starship Bridge Simulator which came out nearly four years earlier than Starfleet Academy.
Reply 5 of 12, by -KRRU-Dominus
feda wrote on 2021-10-25, 17:25:
I would have gladly tried to help / reproduce / fix your problem - there is a lot of trial & error and tweaking involved, but you are clearly not interested - but please let everyone decide for him/herself wich videos are better. Maybe the DVD Videos are looking worse on your setup, but there has to be a reason if that is the case.
What I meant by "objectively better" you can see in the attached screenshot (even though they cheated in the DVD version regarding FPS and resolution - more here https://www.youtube.com/watch?v=VorkPCeDVgY): The DVD Version has higher resolution, higher bitrate, better coloring.
Reply 6 of 12, by -KRRU-Dominus
Updated launch post:
Known Issues:
Reply 7 of 12, by nickp85
Hi there! Just stumbled on this page and I mostly got it working. I am just trying to use the upgraded video/sound and resolution patch. Everything seems to be ok except the starfield issue, lots of graphics artifacts. I am playing 2K resolution centered full screen. Tried all sorts of options in the Voodoo config and can't get it to go away. Any suggestions?
Thanks
Reply 8 of 12, by nickp85
I also just noticed if I do a custom mission, I get the "insert CD1" and can't get past it. Any fix for that?
Reply 9 of 12, by -KRRU-Dominus
nickp85 wrote on 2022-04-13, 03:31:
Sorry, I can´t reproduce. I am aware of the issue when pressing "View Intro" but not when trying to start a custom mission.
Which version are you using? Are you starting the game with sfad3d.exe from the patch?
Reply 10 of 12, by -KRRU-Dominus
nickp85 wrote on 2022-04-13, 02:51:
Thanks
I have small starfield issues in fullscreen mode (pointy lines while moving the ship), but it´s nothing that kept me from playing and finishing the game twice.
I got the best results with those settings:
download/file.php?id=121949&mode=view
I did notice the issue is worse on NVidia cards (AMD seems to be better). Don´t remember if I ever tested on Intel IGP.
Maybe Dege (creator of dgVoodoo2) could look into the issue. I will contact him.
EDIT: Here is the answer and more info on the issue: Graphic Issues in Starfleet Academy
Reply 11 of 12, by davidcgc
-KRRU-Dominus wrote on 2021-06-17, 11:14:
1) You have the GOG or original CD-Version (Steam release was not testet, but should also work)
I decided to give installing SFA with the DVD patch and expansion pack a shot today. I had some difficulty, but got it more-or-less working (I decided my joystick inexplicably inverting the horizontal axis halfway through the first mission could be a problem for another day). I do have a couple things to report.
First, "Chekov's Lost Missions" doesn't work with the Steam release. Whatever the CD installer for the expansion pack uses to check if SFA has been installed, the Steam installation of the game must not do it, so when I tried to run "setup.exe" off the CD, I got an error saying that the expansion pack requires Starfleet Academy version 1.00 or later to be installed. I tried buying the game from GOG and used the stand-alone installer, and then "setup.exe" opened immediately with no complaints. (Don't worry, I was well within the window for a Steam refund, all's well that ends well).
Second, the videos from the expansion pack aren't letterboxed like the ones in the main game. I suspect when the videos were converted from the CD format to the DVD format, the letterboxing was automatically cropped out (I know Handbrake does it by default, for instance), but that means that if you're playing in 16x9, the splash screen and cutscenes for the expansion look fine, but the interface and the main game cutscenes are stretched, and if you play in 4x3, the interface and main game videos look right, but the splash screen and the expansion videos are squished and too tall. EDIT: I just checked the videos in the original CD, and they also aren't letterboxed. I'd have to experiment further to figure out where exactly the problem is and the best way to fix it. The way I see it, either the letterboxing is exclusive to the version of the movies on the DVD, and the CD videos of the base game were never letterboxed same as the expansion pack videos, or the CD videos of the base game were letterboxed, and the expansion pack update allowed the game to play videos that were at any size. Either way, I think the solution would be to add letterboxes to the expansion pack videos and then resave them in the DVD-version's format.
Finally, doing the optional step of updating to the latest version of dgVoodoo2 gave me a ton of trouble. The interface was totally whited out, and once I fixed that, all the videos played in a tiny corner of the screen, plus I couldn't turn off the watermarks. Using the version and support files that came with the patch worked fine.
(I also got the "Insert Disc 1" bug when trying to create a skirmish mission; I hoped that might be another Steam/GoG issue, but it didn't seem to be.)
Thanks for doing this, I'm a Mac user from way back (give or take some light Bootcamping for gaming), so this will be my first chance to see the improved video quality and the expansion pack I missed out on as a kid.
Reply 12 of 12, by -KRRU-Dominus
I have updated the first post.
There is HD-Upgrade video pack ready to be released, thanks to the magnificent work by Owen Davis (https://www.youtube.com/watch?v=2mI1djIE55E) who is responsible for the Wing Commander IV remastered videos as well (https://wcrespace.com/).
We worked together on an HD-upgrade pack for several month, and I will release it in the next few months. Just waiting for a trailer to be finished.
The HD-upgrade pack will fix the videos from the addon. Here is a first look: https://www.youtube.com/watch?v=VorkPCeDVgY
Thanks for the feedback, very much appreciated.
