Keymapper problem
First post, by mattw1996
Hi
I am trying to get my controller to work to play SWOS on dosbox. ctrl + f1 just mutes my computer rather than starting the keymapper. I cannot work out how to start it in an alternate way. Any help would be very much appreciated. Complete novice here......!
Reply 1 of 2, by jmarsh
If you have a current build you can run"config -startmapper" from within DOSBox to launch the keymapper.
Current builds are available from https://yesterplay.net/dosboxece/
(You do not need the ECE version.)
Reply 2 of 2, by mattw1996
thank you very much, worked a treat.
