First post, by ryt
in new version of dosbox i found theat the default core is auto.
how is this diffirent from previous?
when now i play games i get no frame loss, theats great, but instead of 3000 cycles displeyad i see "max", and my cpu usage is more thean 90%.
can theat be bad for cpu?, somewhere i read theat too much cycles can damage cpu.
Reply 1 of 6, by ykhwong
See Section 9 (How to run resource-demanding games) in README.
Reply 2 of 6, by MiniMax
Rank Moderator
Moderator
How hot do your CPU become?
_________________
Reply 3 of 6, by ryt
normal, i think, like every game i play in win
Reply 4 of 6, by ryt
anywhay the new dosbox is great
Reply 5 of 6, by red_avatar
ryt wrote:
in new version of dosbox i found theat the default core is auto. how is this diffirent from previous? when now i play games i ge […]
Then the people who wrote that are idiots. More cycles just makes Dosbox need more CPU power which is no different from running a game that is very demanding. The only way it can damage your CPU would be if you have terrible cooling and the CPU overheats. Even then, your PC should shut off AND it would happen for any other game you play.
Reply 6 of 6, by ryt
thx
