First post, by Rikintosh
This was the first time I've found an AT case from the 90's that deviates from the "office" standard and looks more "gamer". It is a baby AT case with PS/2 keyboard hole/cutout next to the standard dim keyboard hole. It was produced by a Brazilian factory called Troni, but this in turn didn't create the models, basically they brought things from China and put their name.
Its skeleton isn't strong and heavy, it's just tin, and it's fixed by rivets, and it has some gaps that result in creaking during transport.
One more interesting thing, it has a "slot" to install an 80x80 front fan. It also has a full 3-digit display.
It is with a Biostar 8500tvx motherboard, which is not of great quality, but has interesting features, such as onboard PS/2 connector, ps/2 mouse header, usb, and even a fan for the processor. It supposedly has a cache, but I have my suspicions, as there was a time when these cards of dubious quality came with a fake cache.
In this build, a Pentium MMX 233Mhz will be used, without overclocking, with an evercool cooler kit, and edo 60ns memories.
Unfortunately it's hard (and expensive) to find an AT motherboard with an AGP slot, but if I did, it would be perfect for me to use my Voodoo banshee. For now, I'll settle for the current ATI Rage II+DVD SGRAM (4mb?) which even has TV output.
I've managed to find a floppy disk drive that hasn't yellowed over time, and a retro looking DVD drive that will serve me just fine.
And as it couldn't be missing from a Pentium 1, I'll use an ISA Sound Blaster AWE32 sound card with 2mb of simm memory.
Take a look at my blog: http://rikintosh.blogspot.com
My Youtube channel: https://www.youtube.com/channel/UCfRUbxkBmEihBEkIK32Hilg
Reply 1 of 16, by BitWrangler
Nice, it's got a kind of...
look to it.
Reply 2 of 16, by Tetrium
BitWrangler wrote on 2021-11-16, 01:45:
Nice, it's got a kind of... […]
look to it.
Could also be a Cylon thing btw 😜
My retro rigs (old topic)
Report spammers here!
Reply 3 of 16, by Tetrium
Rikintosh wrote on 2021-11-16, 01:37:
This was the first time I've found an AT case from the 90's that deviates from the "office" standard and looks more "gamer". It […]
AT boards with AGP slot were never really common here in The Netherlands. I suppose it's the same where you live.
Motherboards were already transitioning to ATX at the end of the Pentium 1 era (which did not have AGP) and AGP was considered more a high end thing when it was brand new, thus more expensive, thus more common in ATX since ATX was newer and teh future! 😜
AT was mostly budget at the very end of it's live existence (to upgrade older PCs).
But for Pentium 1, AGP is more a convenience (as at this point AGP cards were usually easier to find compared to their PCI equivalents) and less about actual performance.
I think your case looks nice, with the front bezel having that (for me) unique shape. It somehow looks much more modern compared to what was typically seen in late AT tower cases.
Reply 4 of 16, by Rikintosh
I actually didn't even know about the existence of AT cards with AGP, until I found one in a local junkyard, socket 7, with but unfortunately it was broken in one of the corners, making it impossible to repair. The board was gold, and I think it had chipsets via, I believe it was some kind of crap pc chips.
Reply 5 of 16, by pete8475
That case is delightful! Have fun.
Reply 6 of 16, by HangarAte2nds!
The solution, if you want AGP with a MMX "cheap", is to use a SS7 board.
Reply 7 of 16, by Tetrium
Rikintosh wrote on 2021-11-16, 02:37:
Back when I was dumpsterdiving, I found maybe hundreds of (standard) AT boards and at most only a handful of those had an AGP slot.
It's really not at all common. I mean there were boards made but I barely ever saw them here in The Netherlands.
The very first one I found was probably also some crappy PCChips board as the info I did find of it online mentioned how unstable it was regardless of what you tried to run it with xD so that didn't sound very promising 😜
Reply 8 of 16, by PARKE
HangarAte2nds! wrote on 2021-11-16, 06:24:
The VIA Apollo VP3 supports AGP but does not 'officially' fall in the Super Socket 7 because the max fsb is 83MHz.
There is a list of brands here:
https://alchetron.com/Apollo-VP3#Apollo-VP3-b … ed-motherboards
(scroll down)
Reply 9 of 16, by ronyket
When I saw that Troni logo on the case, i thought... Wait a minute, this must be a Brazilian folk in there...
That case looks really really nice, didn't yellow over time, please keep good care of it, it deserves, as it is gorgeous looking!
But about that video card, it was common to find in places like Santa Ifigênia (I see you're also from SP) those no-branded VGAs with TV out, usually with ATi chips on it, or even more common, Riva TNT2 M64.
I had back in the day one of those no-branded ATi Rage Pro 8 MB on my Pentium 166.
Reply 10 of 16, by kixs
There are Slot-1 AT boards. So you can use Pentium II (maybe P3 with some adapters).
Reply 11 of 16, by Rikintosh
ronyket wrote on 2021-11-17, 13:57:
When I saw that Troni logo on the case, i thought... Wait a minute, this must be a Brazilian folk in there... […]
Yeah, actually it was quite yellowish (practically orange), I retrobrighted it.
I recently acquired a card with TV output from Proview (actually with tv tunner), with Cirrus Logic chipset, which I had never seen before.
Reply 12 of 16, by Rikintosh
kixs wrote on 2021-11-17, 14:50:
Yes I know, there are even cheap/easy options like the pc chips m748lmrt that offer slot 1 and socket 370 in AT form on the same card. Her proposal is excellent, the onboard video is cool, but she has TERRIBLE components, plus my case has an intel metal stamp, Pentium MMX, and I would like to use a pentium 1 because of that.
Reply 13 of 16, by kixs
Rikintosh wrote on 2021-11-18, 02:41:
I guess I missed your point. Your only options are SS7 AT boards. There are many but usually don't sell cheap unless you find a good deal. I have good experiences with Gigabyte GA-5AA and Asus P5A-B.
The other route is to keep this board and get a PCI Banshee or do the more standard way a 2D VGA PCI card and a Voodoo2.
Reply 14 of 16, by ronyket
As you're looking for an Baby-AT mainboard, I found two mainboards with this form factor on that Brazilian marketplace that you know.
One is a Pentium II platform, and another one is a Super Socket 7, with AMD K6-2
But those are expensive, very very expensive.
If you want to look for those, the keywords are 'Soyo Socket 7+' and 'ATC-6130'.
I am also looking for a mainboard for my Pentium III machine, but this is an ATX form factor.
(That's why i stumbled across those mainboards as well)
I have a Voodoo 4 4500 AGP fitted in it, but it has problems, and i am almost sure that the problem is the mainboard (an ASUS P3B-F)
Reply 15 of 16, by RaverX
Nice case, it has that 2000-2005 silly "gamer look" combined with the oldschool early 90s.
The display in the middle looks amazing.
Reply 16 of 16, by Rikintosh
ronyket wrote on 2021-11-18, 13:52:
As you're looking for an Baby-AT mainboard, I found two mainboards with this form factor on that Brazilian marketplace that you […]
Yes, I had found it but they have a distorted value, unfortunately the market is full of people without knowledge who think their stuff is worth the same value as something restored, revised and collector.
Generally I have more luck scouring local bazaars and junkyards.
