First post, by red_avatar
I bought a new graphics card for my IBM PC 330 (Pentium 233 MMX running Windows 98 SE) and it works amazing except that I can no longer reboot the PC. Whenever I try to do so, I get a black screen or I get "27k 62Hz Frequency out of range" on my monitor. The PC also clearly does not reboot (no activity, no beeps).
I already removed all other PCI cards and moved it to different slots but that didn't fix anything. It always boots fine, it's always on the reboot that it locks up.
This is a Riva TNT from Creative Labs CT6700. Any idea what could be the cause?
Retro game fanatic.
IBM PS1 386SX25 - 4MB
IBM Aptiva 486SX33 - 8MB - 2GB CF - SB16
IBM PC350 P233MMX - 64MB - 32GB SSD - AWE64 - Voodoo2
PIII600 - 320MB - 480GB SSD - SB Live! - GF4 Ti 4200
i5-2500k - 3GB - SB Audigy 2 - HD 4870
Reply 1 of 8, by Plasma
Make sure it isn't sharing an IRQ with another device. I had problems in the past with my TNT wanting to use IRQ15 for some stupid reason. IIRC I was able to mess with the BIOS settings to force it to use IRQ10.
Reply 2 of 8, by Warlord
sounds like a issue with the TNT Bios. I know that you've had other pci video cards in the system and it worked just fine. It's a long shot but you could pursue the idea that changing it to another compatible one might solve the problem That is if you don't have IRQ sharing issues. If you have a option for PNP OS yes/no and any other control in the bios I'd explore those options.
Reply 3 of 8, by red_avatar
Plasma wrote on 2022-01-14, 18:16:
I tried this - I set IRQ15 to unavailable and it set it to IRQ9. Funnily enough, it will now reboot properly from Windows but not in DOS. In DOS it gives me a different Frequency now: 31 & 70.
I don't mind so much that it locks up in DOS since I can run Windows from DOS anyway - it's going the other way that is annoying if it locks up.
Retro game fanatic.
Reply 4 of 8, by red_avatar
Warlord wrote on 2022-01-14, 19:14:
It may be - the TNT window in Windows says "BIOS: <UNAVAILABLE>" so lord knows what that means. I've tested a dozen games without issues so far so the BIOS can't be very bad ...
Retro game fanatic.
Reply 5 of 8, by Warlord
could be the memory range the tnt bios wants to use isn't availible to it. Somtimes theres option is motherboard bios to reserve that.
Reply 6 of 8, by red_avatar
Warlord wrote on 2022-01-14, 20:30:
I'll have to take a look - IBM BIOS is relatively limited. I can run the majority of DOS games in Windows (some even work in Windows and don't in DOS because of the 64MB memory which Windows seems to cap).
Retro game fanatic.
Reply 7 of 8, by cyberluke
Did you solve it? I seek a similar problem on Super Socket 7 (AMD K6-2+ 450 MHz) with Riva TNT2 Ultra. It works without driver in 640x480 - 16 colours. After installing driver, only a black screen. Switching to Geforce 2 GTS Pro, which is newer, fixes the problem.
Reply 8 of 8, by red_avatar
cyberluke wrote on 2022-02-07, 18:51:
No I gave up on it. I had too many limitations with the IBM PC330 so I switched to a different system entirely. I originally used the Riva TNT and it worked without this issue on that system but have since replaced it with the Voodoo3.
Retro game fanatic.
