First post, by Procyon
This is about Test Drive Le Mans by Eutechnyx (2000) and not Le Mans 24 Hours by Melbourne House (2002).
I managed to get this game running under Windows 10 x64 with the help of dgVoodoo 2 (Direct3D 12 (featurelevel 11.0)) and runs fine with Windows XP SP2/3 compatibility mode.
The only problem I still have is that I can't use analog controls, I've tried my Logitech Rumblepad 2 and F710 and while they're detected, in the options menu it says "Calibration Unavailable" and when driving using the analog sticks feels like digital input.
I've also tried DxWnd but I didn't manage to get the game running, which also has to do that I'm not very familiar with this software.
Reply 1 of 6, by Procyon
I figured it out.
For some reason this game doesn't like my cordless gamepads.
With a wired gamepad it works fine and can access the calibration menu, more importantly I have analog driving controls.
Reply 2 of 6, by Harry_Grunge
I'm facing the same issue. I'm using a wired Xbox One Controller and I cannot set the Left or Right Triggers for Accelerate or Brake. The game doesn't detect them. Is the game not supposed to use Controller Triggers? Or is there something I gotta do in order for the game to detect both Triggers and use them? I would like to know a solution to get this game to recognize and use my Controller's Triggers
Reply 3 of 6, by Pierre32
Harry_Grunge wrote on 2022-01-17, 21:36:
Sometimes that just seems to be how it is, when running old stuff with modern controllers. You may have more luck with a DirectInput controller like a Logi F310 or Sony DS4.
