First post, by Muz
Why are these weird characters showing up when booting up DOS in Pentium MMX?
Reply 1 of 6, by AirIntake
What's in the Autoexec.bat and Config.sys?
Casio BE-300 Advancement Society alumni
Reply 2 of 6, by Azarien
Are you sure there is no virus?
"Confkgwrction" - the nature of those "typos" suggests that something (may be a virus or faulty video memory) is randomly setting bit 1 therefore increasing the value of characters by 2 (so a becomes c, i becomes k etc.
Space becomes ".
BUT faulty video memory would probably also cause some random colors to appear..
Reply 3 of 6, by AirIntake
It looks like one of the things it's doing is trying to initialize the sound card. Perhaps the startup files listed in the Autoexec.bat and Config.sys are infected.
Reply 4 of 6, by BitWrangler
Nothing to see here, as it states...
Confkgwrction "ks"correctly finksjed!!
The I and U are messed up, h is not far away either, is it coincidence they're near each other on the keyboard, what's the common bit in the scan code or ascii, maybe that's stuck.
Reply 5 of 6, by snufkin
It does look like a stuck bit. E.g. <space> is 20 (0010 0000) and " is 22 (0010 0010), so a lot of space is filled with ". Also \ is 5C 0101 1100 but ^ is 5E 0101 1110, so as Azarien said, bit 1 stuck high.
Slightly odd thing is that by the end it can print spaces again, and the prompt is C:\> when it starts out as C:^>
Intermittent contact somewhere?
Reply 6 of 6, by vstrakh
I had similar issues with ISA video card not making good contact in the slot. Reseating the card or moving it to other slot usually fixed this.
