First post, by AirIntake
- Member
I installed my AT6800W using the drivers I found here: https://www.helpjet.net/Fs-34638782-17890554-54863026.html as normal AZT2320 drivers didn't work as this card is a sound & modem combo.
The drivers installed fine in Windows 98SE, but they didn't create the AZTPNP.CFG file properly for DOS configuration, so I created my own based on the one that worked for Phil's AZT2320 based card here: https://www.philscomputerlab.com/hp-mm-pro-16v-a.html.
This got the Sound Blaster Pro support, MIDI, joystick, and modem initialized and working in DOS, however Windows Sound System doesn't work.
My AZTPNP.CFG is as follows:
[CD Path]CDPATH=C:\AZAUDIO\DRIVERS[PNP]SDMA=0BYTE0=7BYTE1=54VID0=AZT3011[DEVICE_00]Description=AT6800W-U Gameport Joystick Device (AZT3011)HardwareID=\AZT3011_DEV0003\FFFFFFFFRealHwID=ENUM\ISAPNP\AZT3011_DEV0003\FFFFFFFFClass=MEDIAPort0=200[DEVICE_01]Description=AT6800W-U MPU-401 Device (AZT3011)HardwareID=\AZT3011_DEV0002\FFFFFFFFRealHwID=ENUM\ISAPNP\AZT3011_DEV0002\FFFFFFFFClass=MEDIAPort0=330IRQ0=9[DEVICE_02]Description=AT6800W-U Audio Device (AZT3011)HardwareID=\AZT3011_DEV0001\FFFFFFFFRealHwID=ENUM\ISAPNP\AZT3011_DEV0001\FFFFFFFFClass=MEDIAPort0=220Port1=388Port2=534IRQ0=5DMA0=1DMA1=5[DEVICE_03]Description=3Com Windows Modem TIHardwareID=\AZT3011_DEV0004\FFFFFFFFRealHwID=ENUM\ISAPNP\AZT3011_DEV0004\FFFFFFFFClass=MODEMPort0=0110IRQ0=10[Hardware Setting]DevNum=10[WIN PATH]winPath=C:\WINDOWS[END]
I've also tried initializing the card using UNISOUND as well, and it does say that WSS is initialized at 534, but still none of the games I have that support WSS work.
Any ideas?
Casio BE-300 Advancement Society (be300.org) alumni
