First post, by baldyfeet
hi i hope someone can help me? i m trying to play indy jones foa.
will open up to config page and when i click play i egt illegal instruction message then thats it i have put dosbox on but dont know how to mount
any help would be the dogs back wheels
cheers
Reply 2 of 15, by wd
Rank DOSBox Author
DOSBox Author
The readme tells you how to mount, it works just fine in dosbox.
Reply 3 of 15, by Reckless
I wasn't implying it didn't... for a newbie, it is somewhat easier under ScummVM however.
Reply 4 of 15, by wd
Rank DOSBox Author
DOSBox Author
Well if the next game is keen he wants to play...
Reply 5 of 15, by baldyfeet
got scumm but that does not seem to find the game or i am not looking in the right place. could you give me the idiot guide to dosbox or scumm
cheers
Reply 6 of 15, by wd
Rank DOSBox Author
DOSBox Author
You have to point scummvm to the directory where indy4 is.
Maybe post a file listing of your indy directory here.
Reply 7 of 15, by baldyfeet
in the scumm it shows all other games and programs except indy?
i am quite a novice at this so anyhelp is thankful
Reply 8 of 15, by baldyfeet
in the scumm i can find other games and programmes but not the indy,
i am quite a novice at this so any help would be good
cheers
Reply 9 of 15, by wd
Rank DOSBox Author
DOSBox Author
The indy4 directory should have files like atlantis.000/atlantis.001,
an exe file and some .ims files, check that they're present.
Reply 10 of 15, by baldyfeet
i amsorry to bother you all on this subject but i am well stuck.
i dont know where to check or look
sorry about this
Reply 11 of 15, by wd
Rank DOSBox Author
DOSBox Author
Well in that indy4 directory 😀
Like when you have a
c:\oldgames\indy4
then check that directory what files are present.
Reply 13 of 15, by wd
Rank DOSBox Author
DOSBox Author
Or it's still packed or something...
Reply 14 of 15, by baldyfeet
yes them files are there
i have scumm and dosbox just dont know how to mount it
cheers
Reply 15 of 15, by Wintermute
You don't need Dosbox, only ScummVM. There is a Readme file included, when you install the program; this should help you get the game running.
If you have further problems you should ask in the forum of Scummvm (http://forums.scummvm.org) and not here!
