First post, by rfnagel
I've recently been having a real blast playing the old JetFighter III Platinum Edition. FYI, the "Platinum Edition" is the same thing as the original JetFighter III with the "Enhanced Campaign CD" installed. I'm almost done playing ALL of the campaigns and missions in the game, but during my gameplay discovered a few bad bugs with some of the campaign missions.
Attached is a ZIP, I call it "JetFighter III Platinum Edition Unofficial Update #4" (as Mission Studios had released three official updates to the game back in the day), that fixes the problems with these missions. Readme included in the ZIP:
This unofficial update fixes problems with several of the campaign mission
files where the next mission in the campaign would constantly loop back to the
current mission, REGARDLESS if you win or lose the current mission.
This unofficial update also fixes problems with several other campaign mission
current mission, unless that you LOSE the current mission.
These fixes now force the next mission in the campaigns to continue to the next
mission, as they should.
The included fixed campaign mission files are:
MSN09038.DAT
MSN12001.DAT
MSN12002.DAT
MSN12003.DAT
MSN12004.DAT
MSN12005.DAT
MSN12006.DAT
MSN12007.DAT
MSN12008.DAT
MSN12009.DAT
MSN12010.DAT
MSN12011.DAT
MSN12012.DAT
MSN12013.DAT
MSN12014.DAT
MSN12015.DAT
To install, simply copy the included files to the "JF3\CAMPAIGN" directory on
your hard drive, overwriting the existing files in that directory.
It's surprising that none of their beta testers (or customers) discovered these bugs back in the day, as they are definitely a showstopper... the affected mission files will NOT allow you to progress to the next campaign mission in the affected campaigns <DUH!>.
Anyhow, these hex-edited mission files fix those problems.
Also attached is a text file with some of the hex offsets for various values that I've discovered while playing the game for your "PILOT##.DAT" pilot data file, as well as the "MSN#####.DAT" campaign mission files. The hex editing investigation for the pilot data file came about because apparently the "JF3PILOT.EXE" Pilot Editing Utility that comes with the Platinum Edition / Enhanced Campaign CD is BROKEN and crashes back to DOS EVERY time (again, <DUH!>).
Anyways, is anyone still playing this old game? If so, you might find these files useful 😀
    JF3PEHEX.TXT
    1.61 KiB
    60 downloads
    JF3UPDT4.ZIP
    555.19 KiB
    62 downloads
Rich ¥Weeds¥ Nagel
http://www.richnagel.net
Reply 1 of 3, by dormcat
Thanks! But I often found the plane "refused to land" i.e. "floating" a few feet above the runway even with engine off. Running it on my P233-MMX could be a bit choppy but on P3-800 it became kinda buggy. 🙄
Reply 2 of 3, by rfnagel
I've never had that problem. Although one time I got "stuck" inside the carrier after making a landing 🤣! Other than that, never had any problems with landings.
I've been running the game under DOSBox, it's quite smooth as long as I set the game resolution to 640x400, no ground shading, and no clouds.
Rich ¥Weeds¥ Nagel
Reply 3 of 3, by rfnagel
I finally completed ALL of the campaigns in JetFighter III Platinum Edition, and here are my final statistics. I completed a total of 125 sorties over the course of 6 different campaigns (not including the initial flight training missions), and have over 54 hours of mission flight time.
610.72 KiB
Rich ¥Weeds¥ Nagel
