First post, by pnkz
- Newbie
Hey everyone!
I managed to dig out a copy of HL with CS1.6 that works under 98SE (green Steam like UI version with CS bots).
The laptop I'm running it on has a much better CPU than GPU, so software rendering gives better results than OpenGL or D3D for the most part, but the lowest I can set it is 640x480. Is there a way to set the software renderer even lower? I'd aim for 512x383, scales better too on a 1024x768 panel. I remember the original non-Steam Sierra release of Half-Life supported lower resolutions, but I don't think getting CS1.6 to work with that would be easy.
Command lines options or registry edits don't work and I tried to hex edit hl.exe and also decrypted sw.dll but didn't find anything that would imply resolutions.
If anyone has any idea or tips, let me know, thanks!
