First post, by SnakePlissken
Hi
I'm having problems with dgvoodoo2 it keeps crashing my games. I use it for older games that don't support high resolutions and to also convert dx9 games to dx11 so they can use windows 11 auto hdr feature. It was working perfectly a few months ago and even played through some games at 8k resolution downsampled. I deleted it and redownloaded it recently now its crashing all my games. Also the watermark wont go away for some reason which wasn't a problem before. I've disabled it and checked the configuration file and it says false and that it's off. I'm trying resident evil 1 remake now which worked perfectly before. Its somewhat working as it comes up with the dgvoodoo watermark and windows says auto hdr is enabled which means its converted it to dx11 but the game just crashes when I load. This worked perfectly a few months back at 8k resolution. I've tried changing all settings and disabled resolution but it still crashing and says memory overrun. I tested other games and they say the same thing. I also tried an earlier version of dgvoodoo but that's the same. I'm using a 3080ti gpu if that helps. Does anyone know what might be causing this?
