First post, by deleted_acc1
Hi, I need help launching the Hero 3D game. I am trying to run it in Windows 98 SE with a disk image mounted in a virtual disk drive (daemon tools).
The main problem is that, as I found out, the emulator conflicts with the physical disk drive. When I start the game, after the videos, the game crashes to the desktop. But when I pull out the power cable of the drive, the game starts perfectly.
Is there a solution to this problem?
Here is the link to game:
LINK REMOVED
Reply 1 of 1, by DosFreak
Closed.
So called "abandonware" is not supported here. Ask for help from where you got it.
Make sure the drive letter for the emulated CD drive is different from the physical. Also alot of 9x games need D: as the driver letter for the CD drive to work properly.
Make your games work offline
