First post, by GigAHerZ
- Oldbie
Board on UT: https://www.ultimateretro.net/en/motherboards/1131
There is a different board in existence: Asus A5P - https://www.ultimateretro.net/en/motherboards/858
And that board exists in both 512kB and 1MB cache variants. For the second one, it has TAG chip on board. For the first one, it uses TAG inside the chipset.
For the Biostar board, it is 512kB only, but it has the TAG chip physically present on board.
So that maybe suggests that just replacing both the cache sram and tag chip for larger ones might work?
Am i missing something? Or maybe some of you have already done it?
Thanks!
