First post, by retrogamerguy1997
For games that support EAX, is there anyway to enable it on modern systems with integrated sound.
Reply 1 of 8, by BEEN_Nath_58
DSOAL is an option
Reply 2 of 8, by lowenz
Last version of DSOAL works fine in Far Cry 64 bit too!
(DSOAL+OpenAL Soft, self-built with VS 2019 CE, both from the master tree)
Reply 3 of 8, by retrogamerguy1997
Thanks, I'll give it a try.
Reply 4 of 8, by lowenz
You must build from source DSOAL (32/64 bit) and put in the same directory the DLL from OpenAL Soft (32/64 bit) renaming it "dsoal-aldrv" (.dll)
If you want to try some already working binaries for 32 bit applications: http://vaporeon.io/hosted/dsoal-builds/dsoal-r391b.7z (May 2020)
Reply 6 of 8, by HunterZ
lowenz wrote on 2020-10-15, 07:35:
Thanks for this - I see they're still being updated too.
Tried it with Baldur's Gate 2, and while it does seem to restore the EAX effects, it also has an issue where some sound effects are almost always panned hard left or right and rarely in the middle. This is probably the game's fault, but it makes me want to turn it back off 🤣
Reply 7 of 8, by lowenz
lastest version: http://vaporeon.io/hosted/dsoal-builds/dsoal-r430.7z (with Open Soft 1.22 but you can just put the newer 1.22.2 Open Soft *32 bit* DLL and rename it "dsoal-aldrv" https://openal-soft.org/openal-binaries/opena … -1.22.2-bin.zip )
For EAX through OpenAL interface (not DSound3D) OpenAL Soft now is perfectly indipendent and capable by itself to do EAX just fine (example: Unreal 2, it CAN'T do EAX through DSound since the first patch in 2003, 'cause it has been designed around Audigy2 OpenAL+EAX3 acceleration)
Same for E*F*X (native OpenAL sound effects system) but that's by design+compliance.
Reply 8 of 8, by Kappa971
HunterZ wrote on 2022-07-25, 05:30:
The EAX implementation of OpenAL Soft still has some problems, probably what you notice is an OpenAL Soft bug.
I may have noticed a similar thing in Prey (here are some video comparisons between X-Fi and OpenAL Soft: https://github.com/kcat/openal-soft/issues/72 … ment-1188821193).
