Zenith GT capacitors
First post, by TimWolf
Going to recap the 22uf 25v button caps on my Zenith with some nice Wurth 105c 5000hr caps. While I'm at it, these other caps, some tants are under the cpu. Very low profile. They still work but as thru are 25yrs+ old I'm pondering doing them as well. Problem is what to use. New tants, ceramics with 2x the voltage, or??? I'm kinda limited due to the height.
Thanks in advance for the input!
Reply 1 of 10, by majestyk
Unlike regular electrolytics Tantalum capacitors don´t age and they cannot dry out. Instead they keep their nominal values for ages.
There´s no need for replacement at all.
Reply 2 of 10, by darry
majestyk wrote on 2022-08-27, 04:55:
In practice, tantalum caps can and do fail, often by going short, which can result in "fireworks" when a given cap heats up enough due to the short.
This is a known failure mode for older (80s and early 90s) tantalum caps. No idea if this is still a concern for newer ones.
Reply 4 of 10, by majestyk
How many shorted SMD-Tantalums have you guys seen going up in fireworks in your lives?
Early, radial Tantalums did have issues when operated near their nominal values (e.g. 16V Tantalum at 12V DC). Even erlier, the first Tantalums needed always a (serial) resistor to limit maximum current.
This isn´t an issue anymore today and I´m convinced it´already wasn´t an issue when SMD Tantalums were introduced.
Reply 5 of 10, by TimWolf
majestyk wrote on 2022-08-27, 13:01:
My Tandy 1000 RLX in 2017ish (back board with the sound) magic smoked a tant. Then I got a bulk lot of ATI Rage DVD cards, and the first one magic smoked. Same cap, on the second, then third card, so I replaced them all on the entire lot (this year) and they all work like a champ. I'm worried about putting an expensive CPU over a little bank of possible TNT, 🤣!
Reply 6 of 10, by pentiumspeed
Yes, I did find 2 already failed in compaq notebooks, blown hole.
Cheers,
Great Northern aka Canada.
Reply 7 of 10, by Romain
TimWolf wrote on 2022-08-27, 01:53:
I've a trick for you : under Windows 95 (only 95, and Not 98), if the ACPI power management system (normaly activated by default) does not cause any BSOD, it is show that these CPU caps are ok.
It shows in less than an hour of use.
Reply 8 of 10, by majestyk
pentiumspeed wrote on 2022-09-12, 18:59:
Cheers,
Good to know! I guess I was just lucky so far...
Reply 9 of 10, by mockingbird
Interesting... I always assumed that the mechanism for failure of tantalum and niobium capacitors was the equivalent of "tin whiskers", or crystalline growths shorting the cathode to anode.
But there's also something else... Distributors are very careful with moisture levels on SMD tantalums... In fact, there's an even industry practice of baking tantalums to dry them out. I wonder why all the fuss and worry about moisture ingress if they're so invincible, as you say.
(Decommissioned:)
Reply 10 of 10, by TimWolf
Wow all good info. The machine was part of a 100 computer haul in a tireless uhaul for 25 years with a rotted out floor on the gulf coast, in a hurricane zone. Humidity was a major factor.
