First post, by clb
Hi all,
I was wondering what is your preferred flat panel display to use for retro gaming? (please let's skip the CRT side of the conversation - I do have multiple of those already)
What I am looking for is a 4:3 one that would support 1600x1200 with as high refresh rate as possible, and a great picture quality of course.
I am currently looking at Dell Ultrasharp 2007 FP, details at https://dl.dell.com/manuals/all-products/esup … guide_en-us.pdf
But it has an unfortunate drawback with the Vertical Scan Range:
"Vertical scan range: 56 Hz to 76 Hz, exception 1600 x 1200 at 60 Hz only"
I would love to have one that would support 1600x1200 at 70 Hz over DVI-D or HDMI. Anyone know if such 4:3 displays exist?
My alternative plan would be to go with a new ASUS ProArt 248QV, which is a 1920x1200 panel, so would enable 1600 x 1200 (hopefully likely at @70hz as well) with pillarboxes: https://www.asus.com/Displays-Desktops/Monito … isplay-PA248QV/
This search made me curious about what you think is the best flat panel? Do you know of 4:3 1600x1200 @ 70 hz (or higher?) displays in existence?
DVI-D or HDMI required (well, maybe 4:3 displays and HDMI won't appear together..). VGA input is a plus, although not absolutely necessary.
