First post, by kahuna
- Member
Hi there,
Back in the day I had a 486DX/33 with a SB16 combo that came with a 2X CDROM unit (all Creative branded). So, that's my "previous experience" if you wish.
Now that I'm a grown up (or at least that's what my wife tells me), I wanted to relive those moments but also improve them if I can.
With that in mind, I'm currently building two different retro PCs for my own entertainment 😉
The first one has a Sound Blaster AWE64 Gold CT4390.
My second build has two sound cards: A SoundBlaster Live! 5.1 SB0060 PCI paired with a Yamaha ISA YMF719E that has a wavetable connector.
Both of them are running Windows 98SE and MS-DOS 6.22 (using different disk drives, I just select which one I want to boot from).
I also have purchased a Dreamblaster X2GS, an S2 and a "Chill and Phil" (joystick/midi port interface) to be able to use them with the SoundBlaster cards.
I'm focusing at the moment more on the first build, with the AWE64.
Yesterday, I assembled the "Chill and Phil" and started testing at first just with Doom. I have all the audio options I need on the Doom setup; I can use the internal MIDI synth of the AWE64 that sounds good, but also use the S2/X2GS that sounds even better. I'm really impressed by the small S2! (at least with Doom).
Anyway, I was testing other games I noticed those are not that flexible configuring the audio options. Sierra games (Space Quest, Kings Quest) throw errors like "unable to initialize the sound device" but then kinda work (badly), I think they're picky on everything including the CPU you use.
Others like Monkey Island didn't seem to have any options to configure the sound device. I actually just learnt this morning about monkey.ini in Monkey Island 1, I'll be testing that later today.
The question I have for you folks is that if there is a way to configure the environment so games will use MIDI through the joystick port. Meaning, that I don't have to go game by game changing settings, hoping they will have the ability to use the MPU401 MIDI / joystick port in the first place. Not sure if that's even possible, but I thought it's worth to ask.
Should I be better with something like the Yamaha ISA card and its wavetable connector? I guess, the MIDI output will use the wavetable (S2 or X2GS) I have connected to it without having to do anything specific on per game basis.
Thank you!
Be free!
