First post, by majestyk
The DFI K6XV3+/66 is a great socket 7 mainboard and I used it in one of my office PCs for years. For no obvious reasons most of the sold mainboards of this model had 512K onboard cache, a few had 2MB (unlike the baby-ATX version that came with 1MB or 2MB more often).
I decided to upgrade one of my 512K boards with a second 512K chip. After soldering the additional chip I intended to have a look at some picture on the web to find out about the jumpering (=positioning of the 0 Ohm resistors) for this configuration, because I only own 512K and 2MB versions.
I was surprised to find next to nothing - loads of 512K boards and a few blurry ones of the 2MB version.
So I had to find out myself. Here are the results:
Resistors R111, R112 and R113 are just for adjusting the cache size shown in the BIOS summary screen (and maybe tell the MCH what cache size to expect).
R111 -> 1024K
R112 -> 2048K
R113 -> 512K
But that´s not all. For 512K the address line A14 of the 32Kx8 TAG chip is grounded by R134 (the one at the bottom of the red circle).
For a cache size of 1Mb this resistor has to be moved to position R133 (the one above R134) to connect it to the MCH.
This is all that´s to be done for 1MB L2 cache.
If you want to upgrade to 2MB, both 64Kx64 SRAM chips must removed and replaced by 128K64 chips and R113 has to be moved to position R112.
In addition R127/R128 and R129/R130 have to be adjusted for the different pinout.
I did not do this here for a reason: For 2MB cache you need a 64Kx8 TAG RAM (32-pin) with 8nS "speed" that offers the additional address lines. The layout of the K6XV3+ is prepared for this but these chips are very very hard to find today.
There are still 128Kx8 chips made today but I never found 8nS ones. If someone has a source for such chips please let me know.
And here´s a picture of the "finished product" (the sticker still says 512K):
Reply 1 of 18, by dr_st
Very interesting. I would consider doing this to my K6XV3+/66, but I suspect that board has severe aging issues, so at this point I don't feel like investing into a board that may die any day...
Reply 2 of 18, by majestyk
Limiting factor are the crappy green electrolytics in the VRM circuitry around the CPU socket. So I would recommend a recap before going any further.
I forgot to mention the cacheable areas:
"Write Through"
512K -> 128MB RAM
1024K -> 256MB RAM
2048K -> 512MB RAM
"Write Back"
512K -> 64MB RAM
1024K -> 128MB RAM
2048K -> 256MB RAM
Reply 3 of 18, by dr_st
majestyk wrote on 2022-11-16, 08:47:
This is most likely what I will do when it starts crashing too frequently.
IIRC, if your installed RAM is larger than the cacheable areas, and you don't have a 2+/3+ CPU (with internal cache), then you will experience performance drops, correct? Can stability suffer as well?
Reply 4 of 18, by majestyk
Depending on the OS and it´s memory usage there will be performance drops. Stability will not be affected.
I should also add that if you are using a "K6 plus" CPU onboard (then) L3 cache becomes an issue of lower importance that doesn´t play a major role in performance.
Don´t wait too long with a recap. Fading electrolytics cause higher ripple on the supply voltages and can stress the chips.
Reply 5 of 18, by majestyk
I found one of my old K6BV3+ /66 the other day that was equipped with just one 1MB cache chip.
I always wanted to upgrade to 2MB but some component was always missing.
The first step is to solder a second 64x128K chip in it´s place.
The second step is to adjust the jumpering. R145 has to be moved to position R143 and R 137 (or R138) to position R203.
The third step is replacing the TAG RAM:
On 512K or 1MB versions there is a 256K chip (32Kx8, 28 pin SOJ 300 MIL) while 2MB boards have a 512K chip (64Kx8, 32 pin SOJ 300MIL). All chips are 8nS.
These 512K chips were made bei Utron and one more manufacturer and are virtually non-existent today. You will find datasheets but no seller offering them.
That´s why I chose a 1MB chip (128Kx8) 10nS hoping a good sample of a 10nS type today might be as good/fast as a bad sample of a 8nS type back in 1999.
These chips are still available, but you have to make sure they´re 300MIL SOJ and that they have the old pinout with Vss and Vcc at pins 32/16. Modern chips have these pins in the middle of the package due to advantages at high frequencies.
Of course there´s one unused address line in the 1MB chip (A16). This line needs to be grounded, the system won´t work with this pin open. There´s a ground pad nearby so this is no effort.
I still have to test this setup to make sure there are no instabilities at 100MHz FSB.
The FIC VA-503+ has 1MB L2 cache and two 512K chips. The TAG RAM is 256K and the layout only provides the 28 landings for this chip.
I have repeatedly read in online boards that there is a "rare 2MB version" of this model. I doubt this ever exixted due to the TAG limitation.
I tested this setup with both 256MB and 512MB RAM:
In the 256MB case all 256MB are being cached in "Write Back" mode, "Write Allocation" gets enabled by BIOS.
If there´s 512MB RAM present, 512Mb are being cached, but BIOS switches to "Write Through" mode to avoid half of the RAM being uncached. Write Allocation is disabled in this case.
Th data from the table of cacheable areas (see above) is correct as we see.
And here´s a picture of the finished product:
Reply 7 of 18, by dr_st
majestyk wrote on 2022-11-16, 08:40:
Seems I have one of the "rare" (?) in-between variants, with 1MB (using one LP61L64128F-4 chip, with the second socket empty). If I understood this thread, it seems that it is not worth it to attempt to upgrade the cache to 2MB, given that the system currently runs with a K6/2+ CPU and 256MB of RAM.
Reply 8 of 18, by Hirsch
According to this article Windows benchmarks gain about 11% profit from 2MB vs 0MB, while there's no difference for 3D gaming:
https://www.anandtech.com/show/211/3
Reply 9 of 18, by majestyk
dr_st wrote on 2023-07-14, 19:58:
... If I understood this thread, it seems that it is not worth it to attempt to upgrade the cache to 2MB, given that the system currently runs with a K6/2+ CPU and 256MB of RAM.
As long as you are using 256MB RAM, 2MB won´t make a difference - when you´re running a "non-plus" CPU, because 1MB L2 cache is sufficient for caching 256MB.
Note that Anand doesn´t say a word about the RAM size used for the tests.
Reply 10 of 18, by Hirsch
I've got an update on getting the required chips. The super rare UT61512JC-8 was not available on Utsource. I googled a bit and found this source:
https://www.wlschip.com/ut61512jc-8-p0719001p1.html
I ordered 12 pieces there and they arrived today:
When having a look at the label printed on the antistatic bag you'll also get this source:
https://www.sic-chip.com/products/ut61512jc-8-719001
Wlschip asked $5 per chip, $40 shipping costs with FedEx (took 5 days from China to Germany) and $6 PayPal fees. FedEx additionally charged EUR 16,60 customs. Altogether this was not cheap, but we have an existing source.
Reply 11 of 18, by majestyk
Thanks for sharing this source!
I think I´ll order a couple just to be prepared for future upgrade projects.
Reply 12 of 18, by SWZSSR
Glad I came across this thread.. been wanting to do this mod for a long time.
Going to order everything to upgrade 2 of my super 7s
Epox EP-MVP3G2 to G5 (Currently 1MB Upgrade to 2MB with TAG)
DFI K6XV3+/66 (Currently 1MB, Upgrade to 2MB with TAG)
Haven’t had much luck finding the EliteMT 64128 chips so far..
5TH / Dual 233MMX / Millennium II 8MB / Voodoo2 12MB
P5A ALI-G / K6-3+@600 / Geforce256DDR / EWS64XL
Thunder 2500 / Dual P3-S 1.4 / 7950GT AGP / Audigy 1
M919-3.4bf / 5x86@180 / Banshee-PCI / Soundscape Elite
AX4GE-Tube / 3.06HT / FX5950Ultra / Tube Audio
Reply 13 of 18, by dr_st
I'm a little confused about the comment on this page:
https://theretroweb.com/motherboards/s/dfi-k6xv3-66-rev.-b
Board is not 2MB L2 capable since it does not support the 64K x 8bit (SOJ-32) SRAM for the necessary TAG addresses.
Is all this is saying that you cannot simply upgrade the cache chips, and also need to upgrade the TAG SRAM chip?
Or is there something in Rev. B+ that makes it incompatible with the upgraded TAG chips? (what can it possibly be)
Reply 14 of 18, by majestyk
Both B1 and B2 versions provide the additional 4 landings for SOJ32 TAG chips.
As soon as you upgrade L2 cache for 2MB the TAG chip nedds to be replaced ba a 64K x 8 or 128K x 8 SOJ32 chip (10 or better 8nS).
Reply 15 of 18, by stef80
@majestyk
Great thread. I have one DFI K6XV3+/66 which does not boot with L2 enabled. Will look into it with this information.
Reply 16 of 18, by magicmanred
What are the differences between the K6Xv3+ and K6BV3+ boards?
Is it just that one is an ATX and other is a Baby form factor? Or are there any other differences?
Reply 18 of 18, by magicmanred
Thank you!
