First post, by jerryt74332
Here is what i have, It works.
https://easyeda.com/jerryt74332/m919-cache-completed_copy
This was my first attempt at anything with easyeda. so cut me some slack, it works.
This is a very close copy of the original. I would like to make a 512 or 1024 next, but dont know how yet.
You can get your boards ordered from anywhere, or I do have on Ebay. You can search if interested.
Reply 1 of 10, by ph4nt0m
Good work. It shouldn't be complicated to make a 1Mb module. It just takes two additional address lines. Needs eight 128Kx8 chips for the cache and one 64Kx8 chip for the tag.
One more thing. I would probably keep using 0805 capacitors instead of 0603. Clock speeds are low enough for this type size. 10uF/6.3V 0805 X5R or Y5V is a good choice and quite inexpensive.
My Active Sales on CPU-World
Reply 2 of 10, by Horun
Thanks ! Maybe will dig out my broken m919 and see if it can be fixed, did not boot last time checked.
Reply 3 of 10, by prospector_1
the page does not exist anymore, anyone have a schematic or something of this project?
Reply 4 of 10, by Sphere478
Dang. This is why we need to be uploading to vogons 🤣
Was this the only project around for this?
If nothing comes of it and someone can guide me on layout/routing who is more familiar with details I can probably replicate it in kicad.
Sphere's PCB projects.
Reply 9 of 10, by Horun
Here are the files jerryt74332 posted. With the info in this topic Lets make new M919 Cache sticks? you could make some.....
The board layout is not correct to his finished schematics iirc....
