First post, by Masejoer
I have a Voodoo Rush (single planar with AT25)that I cannot get working properly in GL Quake, Quake 2 (opengl), or Unreal Tournament (glide). These have frame flicking and frames of corruption. A bunch of other titles all work fine. Quake 3 with voodoo mode works fine.
I started with my Athlon 800 system and a fresh Win98SE install. I've since moved to a Pentium 200 system, and experience the same thing. I've tried every driver I can find for the rush - 4 different compatible packages I found across the web.
The closest search result I found was Problems with a Voodoo Rush card, but it hasn't helped me. I have been working on this for way too many hours.
Does anyone have suggestions for a fix for these games (and probably others I haven't tried)?
