First post, by Bubby_the_Tour_G
Just installed DOSBox 0.70. Things get really slow when typing things in the DOSBox DOS prompt, it loads the game ever so slowly, for example, when trying to run Stunts, the intro screen takes 1 hour to get through, and the audio is chopped into farts. Lowering CPU Cycles to 1 and raising Frameskip to 10 does nothing at all. Checked in Windows Task Manager, and the CPU was still using 100% of itself for this program.
AMD Athlon 64-Bit Processor, 2.0 Ghz+
Asus K8N-E Mobo
Radeon 9800 Pro Video Card
Realtek AC'97 Audio card or drivers or whatever
Reply 1 of 18, by wd
Rank DOSBox Author
DOSBox Author
Try different output= settings.
Reply 2 of 18, by Bubby_the_Tour_G
Changed output= to overlay and core= to dynamic and Cycles to 1 and frameskip to 10... no effect. CPU work output still shoots all the way up to 100% when I run the program.
Reply 3 of 18, by MiniMax
Rank Moderator
Moderator
Cycles to 1?????
Better make that 10000, 20000 or even 30000.
_________________
Reply 4 of 18, by Bubby_the_Tour_G
Set it to 30000, seems to be even slower
Reply 5 of 18, by IIGS_User
If it get slower at higher cycles, the cycles are too high. Now you must lower the cycles, because your real CPU tries to manage more cycles as it can really do.
Klimawandel.
Reply 6 of 18, by Bubby_the_Tour_G
It actually doesn't matter how many cycles I allow, whether it's set to 1 or 30000, it's still extremely slow. And I have a good computer, I'm not running a Commodore 64 or a 386 here.
Reply 7 of 18, by red_avatar
I had a very similar system like yours and it sounds to me rather that your Windows is f**ked up - if Dosbox always uses 100% it's probably windows that is doing something it shouldn't. You could mess with priority and see what it gives though.
Reply 8 of 18, by wd
Rank DOSBox Author
DOSBox Author
Try reducing the priority= settings in dosbox.conf, unplug any joysticks
and disable sound using the games' setup programs.
Reply 9 of 18, by Bubby_the_Tour_G
Still, no effect. I'm gonna try Dosbox in Safe Mode and see if any programs are messing with it.
Reply 10 of 18, by Bubby_the_Tour_G
Crap. Dosbox doesn't run in Safe Mode. Restarted m'puter and disabled most of the unneccessary .exe's that were running in my system memory. Ran Dosbox again... still lagged down and eating 100% of CPU.
Reply 11 of 18, by Bubby_the_Tour_G
I guess my problem remains unsolved... what a bummer
Reply 13 of 18, by Bubby_the_Tour_G
It is.
Reply 14 of 18, by ADDiCT
DOSBox shouldn't use 100% CPU after starting it. There's something wrong with your machine, OS, or setup. Let's try to identify the source of the problem.
- Unplug _all_ USB devices, and disable programs running in the background, like virus scanners, etc.
- Re-Install DOSBox, or copy the default dosbox.conf file into the directory you've installed DOSBox
- Change the "priority=higher,normal" line to "priority=normal,normal"
Start DOSBox (not the game). If it's still using 100% CPU (and i mean 100%, not 85% or 90%), change the "output=" setting in dosbox.conf, and watch the CPU utilization after every "output=" change (just start DOSBox, not the game).
Some general questions:
- Do you have any FPS or other modern 3D games on your machine? If you have, do they run OK?
- Did you install the latest drivers for your graphics card and sound-chip? Is your DirectX up to date?
Reply 15 of 18, by =zum=
Even to me dosbox gives 100% cpu usage, but it runs fast, now set this:
cycles=max
doesn't he work fine now? 😀
Reply 16 of 18, by Bubby_the_Tour_G
Sorry brother, it still refuses to work properly. Still slow like molasses. 🙁
Reply 17 of 18, by Xelasarg
Have you tried reinstalling or repairing windows?
"What's a paladin?!"
Reply 18 of 18, by franpa
i attempted repairing windows once and all it did was cause the computer to reset while starting windows ;\
but that was after recovering from a virus. the virus was gone, but the damage it caused remained...
AMD Ryzen 3700X | ASUS Crosshair Hero VIII (WiFi) | 16GB DDR4 3600MHz RAM | MSI Geforce 1070Ti 8GB | Windows 10 Pro x64.
my website
