First post, by RintaDev
I'm trying to play Descent in FreeDOS, but I need to use both DOS32A and a slowdown program. I'm currently using MoSlo, but I cannot run something like C:drivers\moslo\moslo.com C:freedos\bin\dos32a.exe C:games\descent\descent.exe because MoSlo can't run stuff with command line parameters. Is there a way to slowdown stuff with command line parameters? If not, does anybody know where the file is to replace DOS4GW with DOS32A inside of the descent.exe file?
Reply 1 of 2, by jmarsh
descent -640x480
Runs the game in "hi res" 640x480 mode which runs at a more reasonable speed on faster PCs. You do lose the cockpit overlay display mode though.
Reply 2 of 2, by Gmlb256
Depending on the motherboard chipset and if don't like the barebones HUD in Descent, there is another slowdown utility that relies on ACPI throttling called Throttle. Add the -C command line switch when using it to avoid disabling the L1 cache.
BTW, you can replace the DOS/4GW extender found in the Descent executable with DOS32/A by using the SUNSYS Bind Utility (SB.EXE):
sb /r descent.exe
