First post, by kaputnik
Finally recapped the mobo in my Athlon rig, and now I'm trying to solve a long standing problem. AGP is stuck in 1x mode.
In BIOS the AGP port is set to 4x mode.
CPUz reports 4x as max supported.
The relevant hardware is a Chaintech 7AJA2 KT133A mobo, a Thoroughbred XP 2400+ CPU, and a Geforce Ti4600 GPU. Got Via 4-in-1 driver 4.42 and Detonator 45.23 installed. BIOS is the latest available version, 3A31.
CPUz report with detailed system info:
CPU-Z TXT Report
Binaries
CPU-Z version 1.57
Processors
Number of processors 1
Number of threads 1
APICs
Processor 0
-- Core 0
-- Thread 0 0
Processors Information
Processor 1 ID = 0
Number of cores 1 (max 1)
Number of threads 1 (max 1)
Name AMD Athlon XP
Codename Thoroughbred
Specification AMD Athlon(tm) XP
Package Socket A (462)
CPUID 6.8.1
Extended CPUID 7.8
Core Stepping B0
Technology 0.13 um
Core Speed 1992.7 MHz
Multiplier x FSB 15.0 x 132.8 MHz
Rated Bus speed 265.7 MHz
Instructions sets MMX (+), 3DNow! (+), SSE
L1 Data cache 64 KBytes, 2-way set associative, 64-byte line size
L1 Instruction cache 64 KBytes, 2-way set associative, 64-byte line size
L2 cache 256 KBytes, 16-way set associative, 64-byte line size
FID/VID Control no
K7 Thermal sensor yes
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 02001002h
Max CPUID level 00000001h
Max CPUID ext. level 80000008h
Cache descriptor Level 1, I, 64 KB, 1 thread(s)
Cache descriptor Level 1, D, 64 KB, 1 thread(s)
Cache descriptor Level 2, U, 256 KB, 1 thread(s)
Show last 797 lines
	CPUID
0x00000000 0x00000001 0x68747541 0x444D4163 0x69746E65
0x00000001 0x00000681 0x00000000 0x00000000 0x0383F9FF
0x80000000 0x80000008 0x68747541 0x444D4163 0x69746E65
0x80000001 0x00000781 0x00000000 0x00000000 0xC1C3F9FF
0x80000002 0x20444D41 0x6C687441 0x74286E6F 0x5820296D
0x80000003 0x00000050 0x00000000 0x00000000 0x00000000
0x80000004 0x00000000 0x00000000 0x00000000 0x00000000
0x80000005 0x0408FF08 0xFF20FF10 0x40020140 0x40020140
0x80000006 0x00000000 0x41004100 0x01008140 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x00000001
0x80000008 0x00002022 0x00000000 0x00000000 0x00000000
MSR 0xC0010114 0x0107F928 0xFFFFFFFF
MSR 0xC0010015 0x00000000 0x080B1008
Chipset
Northbridge VIA KT133A rev. 03
Southbridge VIA VT82C686 rev. 40
Graphic Interface AGP
AGP Revision 2.0
AGP Transfer Rate 1x
AGP SBA supported, enabled
Memory Type SDRAM
Memory Size 512 MBytes
Memory Frequency 132.8 MHz (1:1)
DRAM Interleave 4-way
CAS# latency (CL) 3.0
RAS# to CAS# delay (tRCD) 3
RAS# Precharge (tRP) 3
Cycle Time (tRAS) 6
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type SDRAM
Manufacturer (ID) Samsung (CE00000000000000)
Size 512 MBytes
Max bandwidth PC133 (133 MHz)
Part number M3 66S6453CTS-C7A
Serial number 3769800D
Manufacturing date Week 02/Year 03
Number of banks 2
Data width 64 bits
Correction None
Registered no
Buffered no
EPP no
XMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 2.0-2-2-5-n.a. @ 100 MHz
JEDEC #2 3.0-3-3-6-n.a. @ 133 MHz
DIMM # 1
SPD registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 80 08 04 0D 0A 02 40 00 01 75 54 00 82 08 00 01
10 8F 04 06 01 01 00 0E A0 60 00 00 14 0F 14 2D 40
20 15 08 15 08 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 12 D3
40 CE 00 00 00 00 00 00 00 01 4D 33 20 36 36 53 36
50 34 35 33 43 54 53 2D 43 37 41 20 53 43 03 02 37
60 69 80 0D FF 48 42 4C 35 35 30 32 FF FF FF FF FF
70 FF FF FF FF FF FF FF FF FF FF FF FF FF FF 64 FF
80 00 46 C0 0D 02 06 FF FF FF FF FF 02 00 19 FF FF
90 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Monitoring
LPCIO
Hardware Monitors
Hardware monitor VIA 686A/B
Voltage 0 1.60 Volts [0x86] (CPU VCore)
Voltage 1 0.30 Volts [0x19] (AUX)
Voltage 2 3.34 Volts [0xD2] (+3.3V)
Voltage 3 4.95 Volts [0xC8] (+5V)
Voltage 4 11.99 Volts [0xC8] (+12V)
Temperature 0 33°C (91°F) [0x255] (TMPIN0)
Temperature 1 30°C (86°F) [0x239] (TMPIN1)
Temperature 2 24°C (74°F) [0x201] (TMPIN2)
Fan 0 0 RPM [0x0] (FANIN0)
Fan 1 0 RPM [0x0] (FANIN1)
Register space class = 0x13, base address = 0x06000
PCI Devices
Description Host Bridge
Location bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x1106
Model ID 0x0305
Revision ID 0x03
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x08
Header 0x00
PCI header
Address 0 (memory) 0xD0000000
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps class AGP
Caps offset 0xA0
Caps version 2.0
Caps status enabled
Transfer rate 1x (max 1x)
Queue lenght 221 (max 32)
PCI capability
Caps class Power Management
Caps offset 0xC0
Caps version 1.1
PCI registers
00 06 11 05 03 06 00 10 22 03 00 00 06 00 08 00 00
10 08 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 A0 00 00 00 00 00 00 00 00 00 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 17 A3 6B B4 47 0D 20 20 E0 00 10 20 20 20 20 20
60 03 AA 00 20 E6 D4 D4 00 51 0C 43 0D 08 33 00 00
70 DE 88 CC 0C 0E 83 D2 00 01 B4 19 02 00 00 00 00
80 0F 44 00 00 80 00 00 00 03 F0 FB 00 00 00 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 00 32 00 00
A0 02 C0 20 00 01 02 00 1F 01 03 00 00 67 22 00 63
B0 C9 DC 38 18 00 FF 10 05 27 00 00 00 00 00 00 00
C0 01 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 03 04 11 22 00 00 00 00 80 00 00
Description PCI to PCI Bridge
Location bus 0 (0x00), device 1 (0x01), function 0 (0x00)
Common header
Vendor ID 0x1106
Model ID 0x8305
Revision ID 0x00
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x01
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0x80
Caps version 1.1
PCI registers
00 06 11 05 83 07 00 30 22 00 00 04 06 00 00 01 00
10 00 00 00 00 00 00 00 00 00 01 01 00 F0 00 00 00
20 00 E8 F0 E9 00 D8 F0 E7 00 00 00 00 00 00 00 00
30 00 00 00 00 80 00 00 00 00 00 00 00 00 00 08 00
40 CB CD 08 44 25 72 05 83 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 01 00 02 02 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Description PCI to ISA Bridge
Location bus 0 (0x00), device 7 (0x07), function 0 (0x00)
Common header
Vendor ID 0x1106
Model ID 0x0686
Revision ID 0x40
PI 0x00
SubClass 0x01
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1106
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0xC0
Caps version 1.1
PCI registers
00 06 11 86 06 87 00 10 02 40 00 01 06 00 00 80 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 06 11 00 00
30 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00
40 00 01 00 00 00 80 60 EE 01 01 84 00 00 00 F0 F3
50 00 00 00 00 00 B0 00 A0 00 06 FF 08 50 00 00 00
70 00 00 00 00 01 32 00 00 00 00 F0 40 00 00 00 00
80 00 00 00 00 00 0D 00 00 00 60 00 02 00 00 00 00
F0 00 00 00 00 00 00 42 00 00 00 00 00 00 00 00 00
Description IDE Controller
Location bus 0 (0x00), device 7 (0x07), function 1 (0x01)
Common header
Vendor ID 0x1106
Model ID 0x0571
Revision ID 0x06
PI 0x8A
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x20
Header 0x00
PCI header
Address 4 (port) 0x0000D000
Subvendor ID 0x1106
Subsystem ID 0x0571
Int. Line 0xFF
Int. Pin 0x00
PCI capability
Caps offset 0xC0
Caps version 1.1
PCI registers
00 06 11 71 05 07 00 90 02 06 8A 01 01 00 20 00 00
20 01 D0 00 00 00 00 00 00 00 00 00 00 06 11 71 05
30 00 00 00 00 C0 00 00 00 00 00 00 00 FF 00 00 00
40 0B E2 09 35 18 1C C0 00 A8 20 A8 20 FF 00 FF FF
50 03 E4 03 F0 34 00 00 00 A8 A8 A8 A8 00 00 00 00
60 00 02 00 00 00 00 00 00 00 02 00 00 00 00 00 00
70 02 01 00 00 00 00 00 00 02 01 00 00 00 00 00 00
80 74 ED FE 00 00 00 00 00 F4 E9 FE 00 00 00 00 00
D0 06 00 71 05 06 11 71 05 00 00 00 00 00 00 00 00
Description USB Controller (UHCI)
Location bus 0 (0x00), device 7 (0x07), function 2 (0x02)
Common header
Vendor ID 0x1106
Model ID 0x3038
Revision ID 0x1A
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x08
Latency 0x20
Header 0x00
PCI header
Address 4 (port) 0x0000D400
Subvendor ID 0x0925
Subsystem ID 0x1234
Int. Line 0x0A
Int. Pin 0x04
PCI capability
Caps offset 0x80
Caps version 1.1
PCI registers
00 06 11 38 30 07 00 10 02 1A 00 03 0C 08 20 00 00
20 01 D4 00 00 00 00 00 00 00 00 00 00 25 09 34 12
30 00 00 00 00 80 00 00 00 00 00 00 00 0A 04 00 00
40 00 10 03 00 C2 00 00 00 00 00 00 00 00 00 00 00
60 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 01 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 7 (0x07), function 3 (0x03)
Common header
Vendor ID 0x1106
Model ID 0x3038
Revision ID 0x1A
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x08
Latency 0x20
Header 0x00
PCI header
Address 4 (port) 0x0000D800
Subvendor ID 0x0925
Subsystem ID 0x1234
Int. Line 0x0A
Int. Pin 0x04
PCI capability
Caps offset 0x80
Caps version 1.1
PCI registers
20 01 D8 00 00 00 00 00 00 00 00 00 00 25 09 34 12
40 00 10 03 00 C2 00 00 C0 00 00 00 00 00 00 00 00
Description Bridge device
Location bus 0 (0x00), device 7 (0x07), function 4 (0x04)
Common header
Vendor ID 0x1106
Model ID 0x3057
Revision ID 0x40
PI 0x00
SubClass 0x80
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x1106
Subsystem ID 0x3057
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0x68
Caps version 1.1
PCI registers
00 06 11 57 30 00 00 90 02 40 00 80 06 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 06 11 57 30
30 00 00 00 00 68 00 00 00 00 00 00 00 00 00 00 00
40 20 84 57 00 BA 30 00 00 01 40 00 00 00 10 00 00
50 00 FF FB 88 44 04 00 00 00 FF FF 00 06 11 57 30
60 00 00 00 00 00 00 00 00 01 00 02 00 00 00 00 00
70 01 60 00 00 01 00 00 00 00 00 00 00 00 00 00 00
80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
90 01 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 01 00 00 00 40 00 00 00 00 00 00 00 00 00
Description Audio device
Location bus 0 (0x00), device 16 (0x10), function 0 (0x00)
Common header
Vendor ID 0x1102
Model ID 0x0002
Revision ID 0x08
PI 0x00
SubClass 0x01
BaseClass 0x04
Cache Line 0x00
Latency 0x20
Header 0x80
PCI header
Address 0 (port) 0x0000DC00
Subvendor ID 0x1102
Subsystem ID 0x8027
Int. Line 0x0A
Int. Pin 0x01
PCI capability
Caps offset 0xDC
Caps version 1.0
PCI registers
00 02 11 02 00 05 00 90 02 08 00 01 04 00 20 80 00
10 01 DC 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 02 11 27 80
30 00 00 00 00 DC 00 00 00 00 00 00 00 0A 01 02 14
D0 00 00 00 00 00 00 00 00 00 00 00 00 01 00 01 06
Description Input Device
Location bus 0 (0x00), device 16 (0x10), function 1 (0x01)
Common header
Vendor ID 0x1102
Model ID 0x7002
Revision ID 0x08
PI 0x00
SubClass 0x80
BaseClass 0x09
Cache Line 0x00
Latency 0x20
Header 0x80
PCI header
Address 0 (port) 0x00000200
Subvendor ID 0x1102
Subsystem ID 0x0020
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0xDC
Caps version 1.0
PCI registers
00 02 11 02 70 05 00 90 02 08 00 80 09 00 20 80 00
10 01 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 02 11 20 00
30 00 00 00 00 DC 00 00 00 00 00 00 00 00 00 00 00
Description Ethernet Controller
Location bus 0 (0x00), device 17 (0x11), function 0 (0x00)
Common header
Vendor ID 0x10EC
Model ID 0x8139
Revision ID 0x10
PI 0x00
SubClass 0x00
BaseClass 0x02
Cache Line 0x00
Latency 0x20
Header 0x00
PCI header
Address 0 (port) 0x0000E400
Address 1 (memory) 0xEA000000
Subvendor ID 0x10EC
Subsystem ID 0x8139
Int. Line 0x0B
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.1
PCI registers
00 EC 10 39 81 07 00 90 82 10 00 00 02 00 20 00 00
10 01 E4 00 00 00 00 00 EA 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 EC 10 39 81
30 00 00 00 00 50 00 00 00 00 00 00 00 0B 01 20 40
50 01 00 C2 F7 00 00 00 00 00 00 00 00 00 00 00 00
Description VGA Controller
Location bus 1 (0x01), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x0250
Revision ID 0xA3
PI 0x00
SubClass 0x00
BaseClass 0x03
Cache Line 0x00
Latency 0xF8
Header 0x00
PCI header
Address 0 (memory) 0xE8000000
Address 1 (memory) 0xD8000000
Address 2 (memory) 0xE0000000
Subvendor ID 0x10DE
Subsystem ID 0x0130
Int. Line 0x0B
Int. Pin 0x01
PCI capability
Caps offset 0x60
Caps version 1.1
PCI capability
Caps class AGP
Caps offset 0x44
Caps version 2.0
Caps status enabled
Transfer rate 1x (max 4x)
Queue lenght 1 (max 32)
PCI registers
00 DE 10 50 02 07 00 B0 02 A3 00 00 03 00 F8 00 00
10 00 00 00 E8 08 00 00 D8 08 00 00 E0 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 DE 10 30 01
30 00 00 00 00 60 00 00 00 00 00 00 00 0B 01 05 01
40 DE 10 30 01 02 00 20 00 17 02 00 1F 01 03 00 1F
50 01 00 00 00 01 00 00 00 CE D6 23 00 0F 00 00 00
60 01 44 02 00 00 00 00 00 00 00 00 00 00 00 00 00
DMI
DMI BIOS
vendor Award Software International, Inc.
version 6.00 PG
date 10/31/2003
DMI System Information
manufacturer VIA Technologies, Inc.
product VT8363
version unknown
serial unknown
UUID {FFFFFFFF-FFFF-FFFF-FFFF-FFFFFFFFFFFF}
DMI BIOS
vendor unknown
version unknown
date unknown
DMI Baseboard
vendor unknown
model unknown
revision unknown
serial unknown
DMI BIOS
vendor unknown
version unknown
date unknown
DMI System Enclosure
manufacturer unknown
chassis type Desktop
chassis serial unknown
DMI BIOS
vendor unknown
version unknown
date unknown
DMI BIOS
vendor unknown
version unknown
date unknown
DMI BIOS
vendor unknown
version unknown
date unknown
DMI BIOS
vendor unknown
version unknown
date unknown
DMI BIOS
vendor unknown
version COM1
date
DMI BIOS
vendor unknown
version COM2
date
DMI BIOS
vendor unknown
version LPT1
date ÿ
Keyboard
DMI BIOS
vendor unknown
version
Keyboard
date
DMI BIOS
vendor unknown
version PS/2 Mouse
date unknown
DMI Extension Slot
designation ISA
type ISA
width 16 bits
DMI Extension Slot
designation ISA
type ISA
width 16 bits
DMI Extension Slot
designation ISA
type ISA
width 16 bits
DMI Extension Slot
designation ISA
type ISA
width 16 bits
DMI Extension Slot
designation PCI
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI
type PCI
width 32 bits
populated yes
DMI Extension Slot
designation PCI
type PCI
width 32 bits
populated yes
DMI BIOS
vendor unknown
version
date AGP
DMI Port Connector
designation USB (internal)
port type USB
DMI BIOS
vendor unknown
version unknown
date unknown
DMI BIOS
vendor unknown
version unknown
date unknown
DMI BIOS
vendor unknown
version unknown
date unknown
DMI BIOS
vendor unknown
version unknown
date unknown
DMI BIOS
vendor None
version Bank6/7
date
DMI Physical Memory Array
location Motherboard
usage System Memory
correction None
max capacity 2048 MBytes
max# of devices 4
DMI Memory Device
designation BANK_0
format DIMM
type unknown
size 1024 MBytes
DMI Memory Device
designation BANK_1
format DIMM
type unknown
DMI Memory Device
designation BANK_2
format DIMM
type unknown
DMI Memory Device
designation BANK_3
format DIMM
type unknown
Graphics
Number of adapters 1
Graphic APIs
API NVIDIA I/O
Display Adapters
Display adapter 0
Name NVIDIA GeForce4 Ti 4600
Revision A3
Codename NV25
Technology 0.15 um
PCI device bus 1 (0x1), device 0 (0x0), function 0 (0x0)
Vendor ID 0x10DE (0x10DE)
Model ID 0x0250 (0x0130)
Performance Level 0
Software
Windows Version Microsoft Windows 98 SE
DirectX Version 7.0a
ACPI
ACPI Tree
I've visually checked the mobo and GPU for damage, like broken copper traces, missing SMD components etc. Everything looks perfect. Also cleaned the AGP connector thoroughly.
Googled around some, and found a limited amount of info from the time when hardware like this was top of the line, on machines with similar specs exhibiting the same problem. There seems to be no consensus around the underlying reasons though, and no potential fixes. There are indications that the Nvidia driver might lock the AGP port in 1x mode due to instability in higher modes with certain Via chipsets, that sounds plausible.
So, does Vogons have any ideas? 😀
Also, is this even a problem in the reality? Will AGP 1x bottleneck an Athlon XP 2400+ on 266 MT/s FSB, 133 MHz SDRAM, and a Geforce Ti4600 GPU, running games in 1280x1024@75Hz, 32bit color?
Reply 1 of 8, by The Serpent Rider
Yes, it might to some degree. One of the issues is Nvidia TnL engine, which is hungry for bus speed. And if driver has also disabled Sideband Addressing, you're practically working with PCI-66 bandwidth.
Anyway, that's a usual problem with early VIA AGP implementations and Nvidia drivers which can be fixed by using RivaTuner.
Reply 2 of 8, by kaputnik
The Serpent Rider wrote on 2023-07-02, 16:46:
Yes, it might to some degree. One of the issues is Nvidia TnL engine, which is hungry for bus speed. And if driver has also disa […]
Thanks for clearing that up, seems I'll have to find a solution somehow then. SBA is enabled at least 😀
Might be trying to do it the wrong way, but manipulating AGP settings with Rivatuner doesn't seem to help either. The AGP rate selection dropdown menu only gives me the 1x alternative, and modifying the setting manually seems to do nothing either. I've of course rebooted the computer after trying to apply the setting.
Reply 3 of 8, by shevalier
There is a rather idiotic mechanism for determining the voltage, and, accordingly, the mode.
file.php?id=158445&mode=view
Re: HD 4650 AGP ripped out resistors
For 4x, the regulator near the AGP should output 1.5V instead of 3.3V
And the AGPVREF reference level on the Mobo & Video pins should be 0.75V, i.e. equal.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 4 of 8, by The Serpent Rider
kaputnik wrote on 2023-07-02, 17:33:
There's another tab specifically for overriding Nvidia limiters on VIA and other chipsets.
Reply 5 of 8, by Horun
Curious if the BIOS settings are not set proper. My MSI KT board has some AGP settings including Mode (Auto, 4x, 2x) and AGP Fast Writes which also can be troublesome with certain drivers... just a thought.
Reply 6 of 8, by kaputnik
Problem solved! Reinstalling the AGP driver from the Via 4-in-1 package did the trick, now the GPU is running in 4x mode. It also enabled AGP fast writes.
The chipset drivers is the first thing I install after the OS setup. Guess something I've installed after those messed them up.
Thanks for your suggestions though 😀
Reply 7 of 8, by PD2JK
Good job.
When I saw this topic, I was going to say: Did you install the 4-in-1 AGP driver in 'Turbo mode' ?
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Pluto 700 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 8 of 8, by Horun
Great so was a driver issue ! Probably the nVidia driver changed the AGP GART from what you first installed to what it has and was wrong ;p
