Reply 20 of 43, by Takedasun
Unreal 1152x864
49.57 KiB
52.77 KiB
Reply 21 of 43, by Takedasun
Unreal Tournament 99
Demo with a single bot
60.87 KiB
64.85 KiB
68.37 KiB
73.8 KiB
    UT99_lite_demo.zip
    144.9 KiB
    50 downloads
Reply 22 of 43, by Joseph_Joestar
Interesting. I wonder why the TNT2 PRO goes from 23 FPS at 32-bit color with 2.08 drivers to just 9 FPS with 3.68 drivers. That's a huge difference!
Reply 25 of 43, by Takedasun
Half-Life ver. 1.0.1.6
Direct3D
52.9 KiB
57.08 KiB
OpenGL
85.53 KiB
93.16 KiB
Reply 26 of 43, by Eep386
What's interesting is how well the supposedly vastly inferior S3 Savage4 Xtreme manages to hang in there, on this game. Sure it's noticeably slower under 32 bit color, but 16 bit color it's only a little bit slower than the better cards. Perhaps the S3 drivers are sensitive to the CPU and chipset combination used?
Reply 27 of 43, by BitWrangler
Well until you swap the CPU out for a K6-3+ 550 and it gets slow again.
Reply 28 of 43, by Caluser2000
I should imagine one that works would be go.....
Reply 29 of 43, by Eep386
BitWrangler wrote on 2021-08-05, 03:31:
Ought to be just fine for my Pentium MMX 233MHz system. (PCI version anyhow.)
Much as I love 3dfx cards, the prices are absoludicrous anymore.
Reply 30 of 43, by Takedasun
Need for Speed III: Hot Pursuit (Modern Patch for Need for Speed III) 1998.
Direct3D 5
52.69 KiB
58.42 KiB
Direct3D 6
58.38 KiB
62.84 KiB
Reply 32 of 43, by Takedasun
Need For Speed 4: High Stakes
57.01 KiB
60.94 KiB
Reply 33 of 43, by Sphere478
Add a radeon 9800 pro to the tests if you are able to get one to run stable.
Sphere's PCB projects.
Reply 34 of 43, by BitWrangler
Kinda surprised how well the Rage 128 are doing, I don't feel so dumb for owning *cough* several now.
Reply 35 of 43, by Takedasun
Sphere478 wrote on 2023-07-24, 22:00:
There is no way to test the Radeon 9800 right now.
Taking into account the weakness of the platform, most likely the performance will be equal to Radeon 9250 (Catalyst 4.7)
Reply 36 of 43, by Takedasun
Need For Speed 4: High Stakes. (1024x768x16)
596.32 KiB
S3 Savage 4 Xtreme 166/166 Mhz (64-bit, 32MB, ver. 8.10.33)
600.72 KiB
S3 Savage 4 Xtreme 166/166 Mhz (64-bit, 32MB, ver. 8.20.38)
550.45 KiB
S3 Savage 4 Xtreme 166/166 Mhz (64-bit, 32MB, Creative Driver)
545.95 KiB
Riva TNT2 (driver v2.08)
463.61 KiB
Voodoo3
Reply 37 of 43, by Takedasun
Need For Speed 4: High Stakes (1024x768x32)
655.69 KiB
Ati Rage128
626.91 KiB
Matrox G400
673.49 KiB
S3 Savage4
596.09 KiB
Nvidia TNT2
611.56 KiB
Nvidia Geforce 3
Reply 38 of 43, by appiah4
There is a lot of inconsistency wrt the clouds being rendered between those cards as well as between driver versions for the S3 Savage 4.
Reply 39 of 43, by Takedasun
Millennium Soldier: Expendable (DirectX 6) 1999.
47.51 KiB
49.81 KiB
58.05 KiB
62.58 KiB
