First post, by vico
I have this motherboard M748MR Rev:1.3 that is giving me some problems, the boot is very slow and apparently it is because the disk and the cdrom take a long time to be recognized and lately the disk is not recognized and gives an error: "sec master hdd error", sometimes also the serial mouse is not recognized. Apparently these issues are caused by a faulty bios.
I have found the following BIOS but an error is produced when trying to program it into the chip.
https://www.elhvb.com/mboards/pcchips/686_M7x … 702S_2M_AMI.zip
Please help me find a working bios update or give me hints on how to program it correctly.
I am attaching images and a backup of the apparently defective BIOS.
    103.1 KiB
    M748MR Rev1.3.zip
    155.85 KiB
    37 downloads
    766.56 KiB
    1.38 MiB
Reply 1 of 5, by zyga64
Do you have another 2MBit (256kB) flash chips ? It does not necessarily have to be AE29F2008. Looks like your BIOS chip is defective 🙁
1) VLSI SCAMP /286@20 /4M /CL-GD5422 /CMI8330
2) i420EX /486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
3) i430FX /K6-2@400 /64M /Rage Pro PCI /ES1370+YMF718
4) i440BX /P!!!750 /256M /MX440 /SBLive!
5) iB75 /3470s /4G /HD7750 /HDA
Reply 3 of 5, by vico
zyga64 wrote on 2023-07-28, 18:07:
Maybe I could buy one but besides being a 2MBit DIP-32, what other aspects should I consider when choosing it?
Reply 4 of 5, by zyga64
It should be TTL compatible (5V) - not low voltage version.
In my box of 2MBit BIOS chips from old/broken motherboards I have: Winbond W49F002A, w49F002U, SyncMos F29C51002T, SST 39SF020, EON EN29F002 and PMC PM29F002T. Sometimes also location of boot-block is important (top or bottom of flash), but anyway - it is worth to try.
Try to find datasheets of few of those, and check if pinout is the same (to be 100% sure). Even if your TL866 doesn't support some of them there is big chance that with Uniflash 2.0 from here https://soggi.org/motherboards/bios-update-fl … h-utilities.htm you'll be able to hotflash it. I have done it many times successfully.
Reply 5 of 5, by Repo Man11
Check and see if this BIOS is the same one on the Retro Web: https://web.archive.org/web/20061020193316fw_ … d-bios.asp#M748
