First post, by konc
- l33t
Hi guys,
I got a 5 1/4 HD Mitsumi floppy drive today, a perfect match for the case I intended to use it, and of course... it cannot read or format any disk.
It's very clean, lube still alive, mechanisms all move freely. Spindle motor works and the disk rotates, if you manually position the heads they move back to track 0. So I ran ImageDisk (the alignment utility in particular) to check what it's reading: Head 0 is pretty much perfect through all tracks. Head 1 doesn't read anything at all. Based on that I had a closer look at Head 1 (the upper one): it's not exactly parallel to the other and it's dropping more on one side. Excuse the photos but it's difficult to even see it properly, I did try my best.
So my question is, is there any chance that this is normal/ok? I haven't seen anything similar again, it looks to me as if it partially came off. I admit I am prejudiced with this explanation due to poor packaging (the drive was just sitting on a piece of hard foam inside a larger box) but I hope I'm wrong and it's not gone yet.
And it looked sooo good in my case
