First post, by envagyok
My Altec Lansing ACS300 PC speaker set the primary winding of the transformer has shorted. I tried to search based on the data sheet, but Google didn't throw up anything. The type is MAE NS225, 2 voltages come out of it, but I don't know the voltages because of the short circuit.
Do you have any ideas on how to replace it?
    42.97 KiB
    59.9 KiB
Reply 1 of 4, by Tiido
What is the voltage rating on the largest capacitors right after the diode bridge ? Is there just one or are there two (I cannot tell if the transformer has single secondary winding or center tapped one) ?
Reply 2 of 4, by envagyok
Tiido wrote on 2023-12-03, 20:35:
I ask my friend, who repair to me (i dont have skills for electtonic) , but yesterday he says at the bridge is 36v capacitors are.
Reply 3 of 4, by giantclam
If as you say, you "don't have skills for electtonic", how exactly did you determine the transformer primary is shorted?
Reply 4 of 4, by envagyok
My friend said, who try repair to me.
The symptom was the fuse went always from one day.
My friend take out the transformator, unstuck the other electric parts, and the fuse still went away every time.
