First post, by holoprox
Bought recently a 486 MoBo.
A 16v/10uF cap on the +12V rail exploded on first power, sorry for not having a spectacular video!
On the second powering it posted.
I changed the blown capacitor, it concludes the whole POST, BUT it wont load OS.
I tried running 5 different CF cards with proper settings in bios, trough 5 different I/O cards, tried using external XT-IDE BIOS (3 different variants), tried booting from floppy — same result: a blinking cursor 🙁
16 sec. video: https://youtu.be/irBTJqobTT8
Any advice at this point would be helphull!
100+ retro computers on board!
50+ flightsticks!
Reply 1 of 15, by CoffeeOne
holoprox wrote on 2023-12-21, 21:08:
Bought recently a 486 MoBo. A 16v/10uF cap on the +12V rail exploded on first power, sorry for not having a spectacular video! […]
How big is the size of the compact flash card? Did you try with one < 500MB?
Is the flash card recognized by the Bios? The video is not helpful.
EDIT: Sorry overlooked the first screen. So Drive C set to NONE most likely will not work.
Reply 2 of 15, by holoprox
CoffeeOne wrote on 2023-12-21, 21:18:
All the CF cards boot on a other pc's — 512/128/32mb and of course they were set to TYPE 48 or 49 with correct settings taken from the autodetect results on a different MoBo
50+ flightsticks!
Reply 3 of 15, by CoffeeOne
Can you boot from floppy?
The ide card is known good?
EDIT: After looking at your video again (so it was helpful), I think the system just crashes after the POST. It does not even try to boot.
So I guess you are not able to boot from floppy either.
If I am right, the problem is not related to the compact flash card.
Reply 4 of 15, by holoprox
CoffeeOne wrote on 2023-12-21, 21:27:
NO i can not boot from a known good card-fdd-fd combination, and yes all I/O cards work in other systems!
I am sure it is NOT related to CF/I/O/FDD and i tried to turn off cache all i can think about, but no help 🙁
DIAG card says FF (POST done! booting)
50+ flightsticks!
Reply 5 of 15, by CoffeeOne
holoprox wrote on 2023-12-21, 21:32:
I edited my answer. See above, so you have a more severe problem, useless to fool around with various flash cards.
Reply 6 of 15, by CoffeeOne
OK, one more weird thing in your pictures.
The Bios shows 4MB RAM.
But you have 8 30pin modules?
Reply 8 of 15, by holoprox
CoffeeOne wrote on 2023-12-21, 21:42:
Photos and video made separately, tried to lower ram to evade possible problems, nothing helps 🙁
There is a photo (with the video card) with only 4 slots populated 😀
50+ flightsticks!
Reply 9 of 15, by CoffeeOne
holoprox wrote on 2023-12-21, 21:55:
You could try only the other bank with the 4 simms.
Most likely something on the board is damaged.
What happens when you start with no ISA I/O card at all, only the Video card?
Then you should get Floppy not found (because it is set in the Bios)
Reply 10 of 15, by holoprox
CoffeeOne wrote on 2023-12-21, 22:05:
You could try only the other bank with the 4 simms. Most likely something on the board is damaged. What happens when you start w […]
Other banks are "BANK1" (assumed it's working only with "BANK0", tommorow will try this
Starting with NO I/O card gives floppy "not found floppy" error, the bios checks allways fdd (last thing to check after memtest - it runs the memtest 5 times by the way)
It fails the floppy test with a particular cable with 1 fdd end (with twisted portion of course).
50+ flightsticks!
Reply 11 of 15, by CoffeeOne
holoprox wrote on 2023-12-21, 22:13:
Other banks are "BANK1" (assumed it's working only with "BANK0", tommorow will try this Starting with NO I/O card gives floppy " […]
I do not understand your last sentence.
So without I/O card, it behaves correctly => floppy error.
And what happens with I/O card and only the floppy drive connected (No ide device connected)?
Reply 12 of 15, by holoprox
CoffeeOne wrote on 2023-12-21, 22:23:
I do not understand your last sentence. So without I/O card, it behaves correctly => floppy error. […]
With a known good Floppy Drive, cable, diskette and controller it wont read - all tests good, but after going trough POST the floppy blinks once and stops!
50+ flightsticks!
Reply 13 of 15, by CoffeeOne
holoprox wrote on 2023-12-21, 22:27:
So no more output on the screen, right?
Did you try all possible ISA slots for the I/O card?
Reply 14 of 15, by holoprox
CoffeeOne wrote on 2023-12-21, 22:33:
There is a blinking cursor on the screen, tried 3 different slots.
50+ flightsticks!
Reply 15 of 15, by holoprox
This morning a miracle happened — it booted from the 1st try.
The BIOS had lost all settings.
It turns out the single cause (after short investigation) was that it won't work with 1WS setting (it works with 2ws).
On the photos the setting is even 3WS, the non-booting problem may be caused by some older trash in BIOS, but there are no more setting screens?
Boots with 8mb ram(70ns), 256k cache, video & system shadowed & cached) from 512CF.
50+ flightsticks!
