Reply 60 of 68, by DosFreak
The best I was able to come up with in my testing was the EDID Extension 126. The Nvidia driver likely sees that and thinks it is a TV. NVIDIA handles this with driver updates but when you have newer monitors released and no updated drivers then this happens. Likely modifying the EDID on the monitor or in transit (EDID emulation) or possibly using a Quadro card (that has the issue...) would work but other than that you'll need to use older drivers. If someone knew what they were doing they could likely modify the driver.....
Make your games work offline
Reply 61 of 68, by agent_x007
I simply use VGA to DVI active adapter (VC 160A), and bypass all "digital limitation" BS NV does in later drivers.
Alternative would be to use GCN1 GPU (which also doesn't have limitations on DP speed under XP).
Reply 62 of 68, by Killermac
Was there any particular reason for choosing a 750w PSU? I'm considering buying a 650w for my build.
ASUS® SABERTOOTH Z77
Intel® Core™ i7-3770K
Noctua® NH-U12S chromax.black
EVGA® GeForce GTX 980 Ti
Creative® Sound Blaster X-Fi Titanium 7.1
Western Digital® WD_BLACK 1 TB
Crucial® MX500 1TB
Corsair® Dominator 4x4GB 1600MHz
Reply 63 of 68, by Shponglefan
Killermac wrote on 2023-08-04, 13:39:
No specific reason. It just happened to be a spare PSU I had on hand.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 64 of 68, by SureSh0t
Just wanted to make a suggestion. Why not go with XP x64? I know it gets a bad rap for some driver incompatibility back in actual XP days but I've found it to work perfectly fine in my own build.
You could upgrade to a server motherboard and run dual xeons with tons of memory and max out the potential of that 980ti.
I guess to be fair, Server 2003 wouldn't be "XP".
I like what you have so far.
Reply 65 of 68, by Shponglefan
SureSh0t wrote on 2023-08-18, 23:35:
For 16-bit Windows compatibility. When I originally started this system one of my goals was to have compatibility for older 16-bit windows games, mainly Civilization 2.
Even though I've since upgraded the system a lot from what I started with, I've found that Civ 2 has scaled nicely, as it fully supports native 1920x1200 resolution which is awesome.
So I'm keeping 32-bit XP for that reason. 😀
Yeah, the 980Ti is a bit wasted in this build. I've thought about downgrading to an early GPU and maybe doing a Windows 7 build and reallocating the 980Ti there. Though since Steam is discontinuing Win 7 support, I'm also not sure how much mileage I'd get out of a Win 7 build...
Thank you! I'm quite happy with it as it runs basically everything I want it to. 😁
Reply 66 of 68, by gmaverick2k
Nice I've upgraded my xp build with x-fi titanium and silent frozr msi gtx 970 from my daily use build as I've upgraded to silent Asus 3060ti tuf. It's not had much use but hasa large hard drive with a tonne of good games of olde courtesy of mercs123
I may install xp on an iMac 2011 27" that I bought recently but don't have time..
"What's all this racket going on up here, son? You watchin' yer girl cartoons again?"
Reply 67 of 68, by Killermac
Shponglefan wrote on 2023-07-21, 02:06:
mrzmaster wrote on 2023-07-20, 19:50:
How's the Asus PA248QV for XP gaming doing? I was thinking of getting a 16:10 for my upcoming more powerful XP build (currently have an EIZO S2133BK) to stretch its legs into 1920x1200. I started looking at used 16:10 displays but then saw the PA248QV new is pretty reasonable.
For slightly older games at 1024x768 or 800x600, I generally prefer a CRT.
I don't want to be annoying or bother you, but if you have, could you show me a photo of the 1024x768 resolution? I'm not sure whether to get the PA248QV or the EIZO S1233. It's a machine with triple boot between XP, Windows 7 and Windows 10, and although I will enjoy 16:10 a lot, a specific online game that I want to start playing has this resolution as the sharpest.
Crucial® MX500 1TB
Reply 68 of 68, by Shponglefan
Killermac wrote on 2023-12-29, 00:11:
Sure thing. I took a wide shot of 1024x768 and a couple close-ups with different sharpness settings on the monitor (zero and 80 respectively).
Unfortunately the message board software seems to shrink the images upon upload, so these are not the original raw images. This makes it more difficult to see the difference between sharpness levels. In person, there is more of an obvious difference.
