Reply 40 of 43, by 3lectr1c
That's good to know - thanks!
But interesting too...
I've currently searched for FIC models through the wayback machine on pcg.fic.com.tw up through late 2001, so at first I assumed the A380 must have come out after. But I just went and checked later captures - it isn't listed anywhere. There's an A360+, but it still lists the S3 graphics. There's also an A385 but it looks different. Where did you find info on the A380? A google search tells me that it exists, but not anything more. Just links to various likely out-of-stock parts pages.
I probably have too many old laptops.
Reply 41 of 43, by PcBytes
Gericom's manual is where I got the specs from, and since the A380 only updated the HW (Tualatin instead of Coppermine/CuMine-T, Radeon M6 instead of Savage4/Twister, 2x256MB PC133) it's safe to say the Gericom models are exactly the mysterious A380/A380G. Supposedly the G supports GPRS though I have been unable to find anything in that regard.
Reply 42 of 43, by PcBytes
Also to add, it really seems the Gericom is an FIC A380. Here's CPU-Z info on the BIOS tab. Weirdest thing is what its actual BIOS string reads, given the Tualatin isn't pinmodded. I wonder what trickery did FIC or Gericom do to get a 694x to run Tualatin. (as we all know only 694T could natively run Tualatins.)
Reply 43 of 43, by 3lectr1c
Ah so that’s how you ID’d it.
Just also worth noting that the A360 is also a Tualatin, not Coppermine. But it doesn’t have the ATI Graphics.
Not sure about the chipset discrepancy.
All quite strange. I’ll add A380 to the list as an unknown of sorts.
