First post, by Zordaks
I want to place a breakpoint on "read" operations from specific memory address. is this something that the dosbox debugger is capable of and if not is there some debugger that can be run from within dosbox that does have this capability?
Thanks, Tom
Reply 1 of 5, by wd
Rank DOSBox Author
DOSBox Author
No, only memory change (bpm).
AND DO NOT USE CAPS IN YOUR SUBJECT LINE
OTHERWISE YOU WON'T GET ANY ANSWERS ANYMORE.
Reply 2 of 5, by Guest
yeah... so i gathered from the other post i did with caps... 🤣
sorry about that - wont happen again.
thanks
Reply 3 of 5, by HunterZ
(Fixed subject here too)
Reply 4 of 5, by micmic
Has anything changed with either internal DOSBox debugger or other debugger that can run in DOSBox as far as breaking in reads is concerned ?
Reply 5 of 5, by wd
Rank DOSBox Author
DOSBox Author
There was a patch somewhere on the dev forum.
