Best LCD for DOS games running on old hardware
Reply 220 of 233, by ElectroSoldier
arncht wrote on 2024-01-18, 19:01:
At a typical crt the black was far from real black, and the top nit is also not comparable to the nowadays standards.
You would have to have a pretty bad CRT for that to be true though, even more so when compared to an LCD.
Reply 221 of 233, by arncht
ElectroSoldier wrote on 2024-01-19, 02:55:
Sure… everybody talking about the highend very late crts, it was not typical in the 90s. I also had 21” trinitron but it was around 2001-2002, before the lcds, it is terrible for dos. Most of the people used shitty crts at the dos age.
Overdoze of the demoscene
Reply 222 of 233, by dr.zeissler
Really helpfull is a TFT that can change the blacklevel, like Nec 193mi. That helped me a lot when fixing too bright levels on macs and fuzzeling lines on Atari-ST.
Reply 223 of 233, by ElectroSoldier
arncht wrote on 2024-01-19, 06:32:
Yeah I understand that part, in that most people didnt have the best tech at the time, but Im not sure how thats important to what we're talking about here and now.
Reply 224 of 233, by arncht
ElectroSoldier wrote on 2024-01-20, 04:36:
Then you can compare to oled, the crt is dead.
Reply 225 of 233, by ElectroSoldier
What 4:3 OLEDs have you found? that support DOS resolutions?
Reply 227 of 233, by Jo22
Industrial monitors are usually all 4:3, right?
Maybe we can get hold of an embedded monitor in near future that's based on a modern OLED panel?
Reply 229 of 233, by Pierre32
arncht wrote on 2024-01-21, 06:10:
Here you can use the oled for modern purposes, why is it good to limit just for 4:3? I did not get it.
Personally, I want a kinda-period-correct-looking display next to my beige box. It's form over function, sure... but I like it.
Reply 231 of 233, by Jo22
Um, personally I don't want a curved 21:9 screen with a glossy black finish and Ambilight. It irritates me. 🤷‍♂️
I'd rather have a small 4:3 panel I can install in a wooden box.
If needed I will paint it, so it looks a bit like a Commodore 1702 or similar monitor.
Or maybe, make it look like an IBM MDA monitor (design was cloned somewhat often).
The empty space in that box could be used to house a homemade linear power supply! ^^
Edit: There's a catch with the infamous 320x200 resolution (line doubled to 320x400; MCGA mode 13h): It uses non-square pixels.
A CRT doesn't care, because it's mostly working with lines.
320x240 (VGA mode x) and 640x480 (Standard VGA mode 12h) are using square-pixels. They look fine on flat-screens, too.
Edited.
Reply 232 of 233, by elszgensa
Jo22 wrote on 2024-01-21, 11:55:
If you're already re-casing the thing, you could pillar(wooden)box a 16:9 panel. Modern bezels are slim, old displays' weren't, so with a bit of care it should come out looking somewhat decent.
Reply 233 of 233, by Jo22
elszgensa wrote on 2024-01-21, 12:48:
Yes, that's a good workaround.
Something similar came to mind when I thought about making an imitation of round CRT monitor (like those radar tubes).
Such monitors were being used to play Space War! and other mainframe games.
