First post, by sdz
Hello,
The motherboard is an Asrock Z77 Extreme4, with 2 PCI slots (via some Asmedia PCIe to PCI bridge).
If a single Voodoo 2 card is installed, regardless of the PCI slot, it works fine.
If two Voodoo 2 cards are installed (with or without the SLI bridge), right clicking on the desktop -> properties:
Or when trying to run Quake 2 (dxdiag fails in a similar way):
I have tried the following drivers:
v2-w9x-3.01.00 , v2-w9x-3.01.01 , voodoo2-30202 , rkv2dx6303
fastv2-win9x-v30 , fastv2-win9x-v35 , fastv2-win9x-v40ge , fastv2-win9x-v46
It fails in the same way with any of the drivers.
Edit: with a single card, under W98, mojo.exe detects it, and reports the expected info (FBI memory, TMU memory etc). With two cards under W98, it detects only one cards, and incorrectly reports the info (FBI 0MB, Bogus number of TMUs).
Under DOS both cards are detected and the info reported is correct.
Any suggestion is highly appreciated đ
