Another Voodoo 2 SLI bridge
First post, by Tevian
I've had some inspiration after reviving a pair of Voodoo2 cards! I've made a temporary floppy ribbon SLI, but since my retro machine will be open, I thought a cool SLI bridge is in order.
I'm aware of the others available, but I thought I'd give it a shot! I'm not going to have rainbow LEDs on my case or anything, but a simple red-illuminated SLI bridge just sounds freaking awesome to me. The mask and copper will be left out and I'm going with a reasonably thin PCB to allow for the red LEDs to glow!
Going to put in an order tonight for these... What do you all think? Cool or dumb! 🤪
Would be cool if I could power it off the SLI pins, but I'm not sure about the pinout and don't know if there's power there. A simple JST header will supply 12v.
Reply 1 of 32, by Shadzilla
The Voodoo2 text would be upside down in a tower case, no?
Reply 2 of 32, by Tevian
I noticed that! 🤣
Reply 3 of 32, by sdz
You can't power it off the SLI pins.
Also, you could swap just 2 lines, instead of the 4, two of them are grounds.
Maybe also tie all the grounds together into a ground plane?
Reply 4 of 32, by Tevian
Is there a wiring pinout for these bridges somewhere? I'm having trouble finding one.
Reply 7 of 32, by Tevian
smola wrote on 2024-03-09, 11:51:
Here is, few days ago I made one and it works perfectly with two v2 where 1st has 8MB and 2nd has 12MB: http://vogonswiki.com/index.php/How_to_make_a … doo_2_SLI_cable
The smaller one waits for ram mod, there is place on pcb for 8 extra chips.
Thx but I've already made a ribbon for it! I actually followed that pic in fact! 😋
Reply 8 of 32, by Tevian
sdz wrote on 2024-03-09, 11:47:
Tevian wrote on 2024-03-09, 11:33:
Check my post here: 3Dfx Voodoo 2 PCB SLI Bridge / SLI Cable
I did see that post, but I looked again and found the PCB file with a pinout! Thx for referring me back to that. I'll have to make those simple changes!
Reply 9 of 32, by sdz
You're welcome!
Reply 10 of 32, by chinny22
Personally I don't like the red. I'd go with Green to match the cards but that's just personal taste.
but anything that shows off the awesomeness is SLI is cool IMHO
Reply 11 of 32, by pete8475
Like many I made my own cable many years ago from a floppy cable and I wouldn't mind having a PCB but the actual SLI connectors aren't perfectly aligned on my two cards.
Both are the same model too.
Reply 12 of 32, by Tevian
Okay hear me out... I'd really like to put some fans on these guys cus they get pretty hot...
This is my solution to hold 2 x 40mm by 10mm fans top mounted... Thumbs up or thumbs down?
Reply 13 of 32, by H3nrik V!
Tevian wrote on 2024-03-11, 07:01:
Okay hear me out... I'd really like to put some fans on these guys cus they get pretty hot... […]
I like it, but wouldn't it only cool one card properly? Maybe expand the outline to have another fan on the other side do the one card as well, so both are cooled on the gpu side? I know this could give clearance problems with adjacent cards, though.
Reply 14 of 32, by Shadzilla
As above, that airflow is only going to hit the front side of the first card. If you went bigger to get the front and back of both cards I think you could be really pushing the amount of mass you can hang off those SLI connectors?
Reply 15 of 32, by Tevian
H3nrik V! wrote on 2024-03-11, 08:44:
So with the 40mm fans, there should be air coverage for both cards. This layout is more symmetrical, but if I shift the fans over by 10mm, they would both have even coverage. This would put the center line right in the middle of the PCB. I'm also adding heatsinks to my chips so even a little airflow would work.
I was looking 3 fans long, but at nearly 90-100mm span from center to center, two fans would be more than enough I think. And you're totally! This would limit the card heights of nearby cards. If I shift 10mm down, it would only affect the cards lower on the PCI slots and be out of the way from the upper PCI slots.
Reply 16 of 32, by Tevian
Okay, this is an asymmetrical version that puts the 40mm fan centered on the second VooDoo 2 PCB. This would give even airflow for both front ICs but would leave the back of the first PCB with no airflow like the symmetrical version. With only 40mm of span, I might prefer more airflow to the fronts. I think either would work out though and I wouldn't want bigger than 40mm...
Reply 17 of 32, by H3nrik V!
Looks really cool! You could, however also go with one off-center and one centered, to have the best of both worlds 🤣
Alternatively a version with an extra card's spacing in between 😉
But yeah, won't make sense to have more versions fabricated ...
Reply 18 of 32, by Tevian
Okay... I'm way past my bedtime but I found a 3D model of a Voodoo 2 card here https://sketchfab.com/3d-models/videocard-3df … 4dcae4c0ed22479
The model was Blender to Fusion so it's all black with no texture. I'm so tired I don't care at the moment... But, it would look badass!
Reply 19 of 32, by Tevian
First, thx to @matze79 @sdz @Sphere478 and everyone who contributed to the post 3Dfx Voodoo 2 PCB SLI Bridge / SLI Cable about the PCB SLI bridge! I also wanted something special for my retro build and that post gave me some inspiration! Thank you!
The first test board worked and the simple backlight worked like a charm! The pictures are crummy and I'll do a better one once the other test board comes.
This is the first ver but I've changed the silkscreen "VOODOO2" to be a mask layer relief so it will be metallic. This was also a "bad" trace route and decided to go with a ground plan with the second version. This was just a test PCB of course.
