Reply 40 of 44, by feipoa
- l33t++
Ya, sometimes you need to play around with the driver order, before HIMEM or after HIMEM. Generally, right before HIMEM is best. I have also seen it where I cannot have DOS=HIGH in config.sys, that is, I must only have written DOS=UMB.
You said that you cannot load DOS HIGH, but then you write DOS=HIGH,UMB. Isn't this loading DOS to high memory first?
