Reply 1581 of 1724, by sharangad
robertmo3 wrote on 2024-05-18, 09:56:
no doesn't help
OK, this will take longer.
https://www.youtube.com/@sharangadayananda
Reply 1582 of 1724, by robertmo3
this reminds me disappearing textures to black on new tracks in cart racing
and also i got disappearing textures to black in rebel moon rising on the second level (first level is a practice level very short, second one is big)
Reply 1583 of 1724, by sharangad
no doesn't help
If you enable dma with the environment var does it work?
Reply 1584 of 1724, by sharangad
robertmo3 wrote on 2024-05-18, 10:06:
Could be. There could also be other bugs compounding the problem.
Reply 1587 of 1724, by sharangad
robertmo3 wrote on 2024-05-18, 10:28:
2 cores doesn't help 2 cores slowed down to 1,5MHz doesn't help too 4 cores slowed down to 1,5MHz doesn't help too i wonder why […]
i wonder why your sandy bridge had no problems
It's probably a logic error. I get corrupted textures in Nascar 2, but not '99.
Reply 1589 of 1724, by robertmo3
if you do exactly the same than i think it is the same
if you for example start the manor
but if you go to title and start the manor again, you may have more textures correct
sometimes different textures are correct, different are black, different are corrupted like the distant view corruption before.
but when you play i think textures are not disappearing
Reply 1591 of 1724, by sharangad
robertmo3 wrote on 2024-05-18, 16:03:
tested on Phenom X4 9550 with gtx660ti win11 and it is the same there
Ok.
Reply 1592 of 1724, by sharangad
I'll try and get you a build tomorrow.
Reply 1593 of 1724, by sharangad
@robertmo3,
For Tomb Raider:
1) This is the base build (it may work. It's a lot newer than the last release.):
https://1drv.ms/u/c/5277ef8d4f2a9dcf/EQwlQqTp … RArR1w?e=Zllxt2
MD5: 31c27a11cbdf1013de3e1cefadb2221d
Try replacing DosClientin the RLauncher folder (and running dosbox through RLauncher):
and using one of these builds:
https://1drv.ms/u/c/5277ef8d4f2a9dcf/ETpbd4z4 … UIH3Gw?e=9tvtZG
MD5: fc367e915721426e2d9a1aa4943e321
I have been able to reproduce your issue, but only if I disabled the mem write detection bitmap. It has been enabled on all builds for a while. So I'm not entirely sure how your copy of TR1 is managing to disable it.
Reply 1594 of 1724, by sharangad
If none of these builds work, the reversion will be a bit more severe.
Reply 1597 of 1724, by sharangad
robertmo3 wrote on 2024-05-19, 02:33:
i think we use same copy of tomb.exe provided in this thread
you can try deleting SETTINGS.DAT
Now I get a black screen when starting a level.
[EDIT] nm. Needs to be run from my batch file.
Reply 1598 of 1724, by sharangad
Your corrupted texture problem is caused by RReady and not dosbox-rendition/DosClient.
Using the latest dosbox with redline and verite dlls from the May 12th release fixes the texture corruption in Nascar 2, or at least it does for me.
[EDIT] redline and Verite also need to be updated along with DosClient.
[EDIT2] But yes, I occasionally do get corrupted textures, but not en masse.
