Horun wrote on 2019-12-14, 15:42:
Thank you very much ! I went thru about 10 different old archives last night and not one of the bulletins would load. Ok so W1 thru W4 are not really documented as to what they do, a close inspection of the card it appears that W2, 3 and 4 go to ISA pins but will have to use DVM to make sure. The card I have has BIOS EDPT10A paper label so maybe one of the first editions.
Any chance you could upload that ROM? Is it 16KB or 32KB?
I got these roms uploaded:
DTC 1181 EIDE Bios v1.2 LBA Support 32KB Rom - http://www.vogonsdrivers.com/getfile.php?fileid=2095
Bios strings:
EIDE22A 04/02/98. (C) COPYRIGHT 1996-1999 DTC Data Technology Corporation
DTC YEAR 2000 (Y2K) Management BIOS Y2K12A 03/08/99, Address C8000H
DTC 1181 EIDE Bios v1.3 LBA Support 16KB Rom - http://www.vogonsdrivers.com/getfile.php?fileid=2087
Bios strings:
DTC YEAR 2000 (Y2K) Management BIOS Y2K13A 05/17/99, Address C8000H
Looks like they both have the same EIDE code. Looks like it is supported by this driver:
DTC EIDE Drivers v20 - http://www.vogonsdrivers.com/getfile.php?file … menustate=56,55
Looks like V1.3 has slightly newer Y2K support.
I have a 1181 with the v1.2 32KB rom. I tried putting the 16KB v1.3 rom on a 32KB 27c256 EPROM but it didn't work. I probably should have doubled up the ROM image.
