First post, by ontrca
I have a FIC PA-2005(v1.3) motherboard with 256k cache factory soldered onboard.
According to the manual it is upgradable to 512k or 1mb and compatible
with (Winbond W25P022AF-6 64Kx32) Pipeline Burst SRAM.
So that's what I bought.
I am doing the cache upgrade myself (or trying to) 😀
I desoldered the 2 old chips and soldered on 2 of the new chips for a total of 512k to test before I went through the trouble of soldering the whole 1mb (4 chips).
In case you're wondering I tested everything, and all the contacts are good, and nothing is shorted together 😀
But then I read online that you have to change some onboard resistors or something??
Also In order to upgrade to 512KB/1MB cache it needs a 32Kx8 TAG but it came with one from the factory so it's good to go 😀
So that is my question..., can anyone help me? Does anyone know what resistors or whatever I'm supposed to change? 😀
Reply 1 of 37, by majestyk
I can tell you the jumpering for 512K, I upgraded two of my PA-2005 a while ago. I never bothered trying 1MB because I usually don´t need 256MB RAM on mainboards like this.
You should also populate Jumper "CLK3" and try if 75 MHz FSB runs stable. In most cases it does.
Reply 2 of 37, by douglar
Sounds like an exciting project. I don't see anything in the manual for selecting the cache size, but I guess that's not a surprise since it wasn't supposed to be user selectable.
Have you upgraded the BIOS?
https://theretroweb.com/motherboards/s/fic-pa-2005#bios
Reply 3 of 37, by ontrca
majestyk wrote on 2024-05-15, 05:36:
I'd appreciate any type of help 😀 Thank You 😀
Reply 4 of 37, by ontrca
douglar wrote on 2024-05-15, 12:51:
I was thinking about that but wasn't sure if it would help 😀
I'll try it 😀 Thank You 😀
Reply 5 of 37, by ontrca
ontrca wrote on 2024-05-19, 00:09:
I updated to this BIOS from "theretroweb.com"
"07/15/97-VT82C580VP-2A5LA008C-00 Vobis OEM 4.51PG VBS1.03D8"
And that didn't help :3
Reply 6 of 37, by majestyk
For a 512K configuration you must move R162 (0 ohm) to position R161 for connecting A13 of the TAG chip to the chipset and R148 (0 ohm) to position R147 for connecting CA 18 = Pin34 of the C585VP to the cache chips.
For 1M cache you will also have to connect address line A14 of the TAG chip to the chipset by adding a 0 ohm resistor at position R164. After that the modifications at the TAG chip are complete.
You also will have to modify the resistors at the C585VP to connect address line CA19 = pin35 to the cache chips. You do this by adding a 0 ohm resistor at position R150.
Reply 7 of 37, by ontrca
Thank You Very Much! I can't wait to try it! 😀
Reply 8 of 37, by ontrca
I will try the 512K configuration first 😀
Reply 9 of 37, by ontrca
majestyk wrote on 2024-05-19, 07:00:
For a 512K configuration you must move R162 (0 ohm) to position R161 for connecting A13 of the TAG chip to the chipset and R148 […]
Well dang that sucks 🙁
My 512k cache upgrade still doesn't work.
I followed your 512K configuration and,
I checked all of my solder points again for shorts and stuff and everything seems to be correct but still not working 🙁
Maybe one of my cache chips are bad 🙁
Reply 10 of 37, by majestyk
I always used a 4-chip 32Kx32 setup for 512K so far. I never cared if and how the A15 pins of the chips are wired and weather they are connected to the chipset.
On the silkscreen printing the 4 positions are marked "32K x 32", but that doesn´t necessarily mean 64Kx32 chips are not supported - at least the A15 pins (pin 49) are connected in some way.
Maybe I will try 4 chips 64Kx32 next week
Reply 11 of 37, by ontrca
majestyk wrote on 2024-05-20, 07:16:
According to the manual the motherboard supports 64Kx32 chips in 512k and 1mb configurations 😀
Reply 12 of 37, by ontrca
And also according to the manual the motherboard is compatible with the cache chips that I bought 😀
Reply 13 of 37, by majestyk
Today I put 4 64K x32 chips on one of my PA2005 and it´s working perfectly.
There´s one thing I forgot to mention:
When you add the 0 Ohm resistor at position R150 you must also remove the one at position R147 (and R148 if present).
L2 is just 25% faster than RAM. If there are some hidden settings for timings in this BIOS it might be worth playing with them.
Reply 14 of 37, by Nexxen
Looks like factory soldered... thumb up!
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
Reply 15 of 37, by ontrca
majestyk wrote on 2024-05-22, 17:50:
Today I put 4 64K x32 chips on one of my PA2005 and it´s working perfectly. […]
Ok Thank You 😀
I'll go ahead give it a try and solder my other 2 chips on the board 😀
I wish I had a hot air station but I'm kinda glad I don't because it gives me a chance to practice my hand soldering since I'm still new at this 😀
Reply 16 of 37, by ontrca
I soldered in my other 2 cache chips (total 4(1mb))
Followed your directions/pictures and it still doesn't work 🙁
I still think maybe one of my cache chips may be bad?? 🙁
oh well... I'll recheck all of solder points AGAIN later/.......... 🙁
Reply 17 of 37, by majestyk
One single un-/ loose-connected pin at one of the chips will prevent the whole L2 cache from getting initialized by BIOS.
Check all the solderings carefully for shorts and bad contacts!
Reply 18 of 37, by ontrca
majestyk wrote on 2024-05-24, 08:40:
Ok 😀
Thank You 😀
I will try today 😀
Reply 19 of 37, by ontrca
I checked all of my solder points again, still not working 🙁
Everything is making contact, nothing is shorted.
I was thinking about reflowing everything just for the heck of it....
Is it possible to have a bad new cache chip?
