First post, by MightyJalapeno
c:\mps\magic\magic
YOU MUST RUN INSTALL BEFORE PLAYING MASTER OF MAGIC.
c:\mps\magic\install
I go through, click "No Sound" because sound never works on this game anyways, and save, and exit.
c:\mps\magic\magic
No matter how many times I run install, it will not let me play this game. Assistance, sil vous plait?
Reply 1 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
check for read only attributes
Water flows down the stream
Reply 2 of 3, by Celes
It's one of my favorite games. I own it and used to play it w/ a cd back in the day, but I have since downloaded it and I have it running perfect with DosBox- sound and all!
To figure out the problem, you're going to have to provide us with more info. I just joined, but I noticed there are rules for posting on the main board that have some guidelines on what sort of info people need to give help.
I never was able to beat it with the impossible setting, all opponents, but occasionally I try. 😀
- Celes -
http://www.theseize.com
http://www.ccceramics.com
Reply 3 of 3, by MightyJalapeno
Ok, I fixed it... apparently, it ONLY works with the SOundblaster settings I saw in the config file. No Sound will NOT work... wierd....
YAYY!!!! Sound!!! Myrrans!!! Cruel Unminding!!!
