First post, by OSH
- Member
I have one simple question: Does anybody run this game under DOSBOX in 16-bit color mode? I've downloaded a patch for european version (because I have an european version), during installing I've chosen an option 16-bit/Pentium processor. After installing the game runs only in 256-color mode...
My DOSBOX-config:
fullscreen=falsefulldouble=falsefullresolution=0x0windowresolution=originaloutput=surfaceautolock=truesensitivity=100waitonerror=truepriority=higher,normalmapperfile=mapper.txtpixelshader=noneusescancodes=false[dosbox]# language -- Select another language file.# memsize -- Amount of memory DOSBox has in megabytes.# machine -- The type of machine tries to emulate:hercules,cga,tandy,pcjr,vga.# captures -- Directory where things like wave,midi,screenshot get captured.language=machine=vgacaptures=capturememsize=32[render]# frameskip -- How many frames DOSBox skips before drawing one.# aspect -- Do aspect correction, if your output method doesn't support scaling this can slow things down!.# scaler -- Scaler used to enlarge/enhance low resolution modes.# Supported are none,normal2x,normal3x,advmame2x,advmame3x,hq2x,hq3x,# 2xsai,super2xsai,supereagle,advinterp2x,advinterp3x,# tv2x,tv3x,rgb2x,rgb3x,scan2x,scan3x.# If forced is appended (like scaler=hq2x forced), the scaler will be used# even if the result might not be desired.# Hardware modes (all except surface) also support hardware2x or hardware3x, use for hardware scaling.frameskip=0aspect=falsescaler=normal2x[cpu]# core -- CPU Core used in emulation: normal,simple,dynamic,auto.# auto switches from normal to dynamic if appropriate.# cycles -- Amount of instructions DOSBox tries to emulate each millisecond.# Setting this value too high results in sound dropouts and lags.# You can also let DOSBox guess the correct value by setting it to max.# The default setting (auto) switches to max if appropriate.# cycleup -- Amount of cycles to increase/decrease with keycombo.# cycledown Setting it lower than 100 will be a percentage.core=normalcycles=5000cycleup=500cycledown=20[vga]# svgachipset -- Select one of the following supported SVGA chipsets:# s3 (default), et4000, et4000new, et3000, pvga1a, or none.# Full chipset name (like 'Tseng ET4000') will also work# as long as it contains one of the strings above.# videoram -- Amount of video memory on emulated SVGA. Not all emulated# chipsets support this setting.
svgachipset=s3videoram=4096[mixer]# nosound -- Enable silent mode, sound is still emulated though.# rate -- Mixer sample rate, setting any devices higher than this will# probably lower their sound quality.# blocksize -- Mixer block size, larger blocks might help sound stuttering# but sound will also be more lagged.# prebuffer -- How many milliseconds of data to keep on top of the blocksize.nosound=falserate=22050blocksize=2048prebuffer=10[midi]# mpu401 -- Type of MPU-401 to emulate: none, uart or intelligent.# device -- Device that will receive the MIDI data from MPU-401.# This can be default,alsa,oss,win32,coreaudio,mt32,none.# mt32rate -- Sample rate of MT32 emulation# config -- Special configuration options for the device. In Windows put# the id of the device you want to use. See README for details.mpu401=uartdevice=defaultmt32rate=22050config=[sblaster]# sbtype -- Type of sblaster to emulate:none,sb1,sb2,sbpro1,sbpro2,sb16.# sbbase,irq,dma,hdma -- The IO/IRQ/DMA/High DMA address of the soundblaster.# mixer -- Allow the soundblaster mixer to modify the DOSBox mixer.# oplmode -- Type of OPL emulation: auto,cms,opl2,dualopl2,opl3,hardware.# On auto the mode is determined by sblaster type.# All OPL modes are 'Adlib', except for CMS.# oplrate -- Sample rate of OPL music emulation.# hardwarebase -- base address of the real hardware soundblaster:# 210,220,230,240,250,260,280sbtype=sb16sbbase=220irq=7dma=1hdma=5mixer=trueoplmode=autooplrate=44100hardwarebase=220[gus]# gus -- Enable the Gravis Ultrasound emulation.# gusbase,irq1,irq2,dma1,dma2 -- The IO/IRQ/DMA addresses of the# Gravis Ultrasound. (Same IRQ's and DMA's are OK.)# gusrate -- Sample rate of Ultrasound emulation.# ultradir -- Path to Ultrasound directory. In this directory# there should be a MIDI directory that contains# the patch files for GUS playback. Patch sets used# with Timidity should work fine.gus=truegusrate=44100gusbase=240irq1=5irq2=5dma1=3dma2=3ultradir=D:\ultrasnd[speaker]# pcspeaker -- Enable PC-Speaker emulation.# pcrate -- Sample rate of the PC-Speaker sound generation.# tandy -- Enable Tandy Sound System emulation (off,on,auto).# For auto Tandysound emulation is present only if machine is set to tandy.# tandyrate -- Sample rate of the Tandy 3-Voice generation.# disney -- Enable Disney Sound Source emulation. Covox Voice Master and Speech Thing compatible.pcspeaker=truepcrate=22050tandy=autotandyrate=22050disney=false[joystick]# joysticktype -- Type of joystick to emulate: auto (default), none,# 2axis (supports two joysticks,# 4axis (supports one joystick, first joystick used),# 4axis_2 (supports one joystick, second joystick used),# fcs (Thrustmaster), ch (CH Flightstick).# none disables joystick emulation.# auto chooses emulation depending on real joystick(s).# timed -- enable timed intervals for axis. (false is old style behaviour).# autofire -- continuously fires as long as you keep the button pressed.# swap34 -- swap the 3rd and the 4th axis. can be useful for certain joysticks.# buttonwrap -- enable button wrapping at the number of emulated buttons.joysticktype=2axistimed=falseautofire=falseswap34=falsebuttonwrap=true[serial]# serial1-4 -- set type of device connected to com port.# Can be disabled, dummy, modem, nullmodem, directserial.# Additional parameters must be in the same line in the form of# parameter:value. Parameter for all types is irq.# for directserial: realport (required), rxdelay (optional).# for modem: listenport (optional).# for nullmodem: server, rxdelay, txdelay, telnet, usedtr,# transparent, port, inhsocket (all optional).# Example: serial1=modem listenport:5000serial1=dummyserial2=dummyserial3=disabledserial4=disabled[parallel]# parallel1-3 -- set type of device connected to lpt port.# Can be reallpt (win32 only)# Additional parameters must be in the same line in the form of# parameter:value.# for directlpt: realaddress (the base address of your real parallel port).# Can be 378, 278 or 3BC. The first two can be ECP ports.# Default: 378# You have to install the PortTalk driver from# http://www.beyondlogic.org/porttalk/porttalk.htm first.parallel1=disabledparallel2=disabledparallel3=disabled[glide]# glide - Enable glide emulation: true,false.glide=false[dos]# xms -- Enable XMS support.# ems -- Enable EMS support.# umb -- Enable UMB support.# keyboardlayout -- Language code of the keyboard layout (or none).xms=trueems=trueumb=truekeyboardlayout=none[ipx]# ipx -- Enable ipx over UDP/IP emulation.ipx=false
