First post, by ives48
Hello -- I'm running a custom DOS app on dosbox 0.71 on PuppyLinux 4. In the code, I need to both write to and read from some custom boards at port addresses 0x300 through 0x31A. I see some sections for port access for sound blaster cards etc, but I don't see how I can configure for access to generic ports. Dosemu allows this with the $ports setting, but for some reason runs the app extremely slowly. Dosbox runs the app at the expected speed, but can't write to the ports. Aaargh!!!
Thanks in advance for any help.
Reply 1 of 2, by MiniMax
Rank Moderator
Moderator
I would be very surprised if this is possible woth DOSBox. There are some tweaked builds of DOSBox for Windows floating around that permits something like that, but it is not AFAIK a standard feature in DOSBox.
_________________
Reply 2 of 2, by ives48
Thanks ... that may be the best help I can get: to know I'm using the wrong tool! I'll switch to Dosemu for this one.
