First post, by cookertron
Hi Vogons,
I have a USB PS2 card that slots into the a PCI connector. Is there any chance I can get this to work on my ASUS P97-S under Windows 95. I've scoured the web but no luck. I'm really not that interested in getting USB to work, I just need PS2 for a mouse.
Thank you
Anthony
Asus P5A v1.06, Gigabyte GA-6BXDS, Soyo SY-5EMA (faulty), Viglen 486, Asus SP97-V
Reply 1 of 17, by red-ray
Exactly what card is it? If it's https://www.ebay.co.uk/itm/203687478151 then it's simply a USB card with a USB to PS2 adapter and to get the mouse to work you will first need to get USB working then find a USB Mouse Driver.
Reply 2 of 17, by cookertron
red-ray wrote on 2023-01-15, 00:49:
Hmmm, I've tried getting USB to work by installing xusbsupp but I don't have the right version of w95 installed sigh!
Reply 4 of 17, by darry
cookertron wrote on 2023-01-15, 00:23:
Hi Vogons, […]
Hi Vogons,
Thank you
Anthony
First, what is an "Asus P97-S" ? I can't find any reference to that anywhere, so I presume that there's a typo somewhere. Can you verify and confirm or infirm this ?
a) If that is late generation AT format board (rather than ATX), it likely has a PS/2 compatible pin header on it to which you could connect a female mini DIN connector to have a functional PS/2 port.
EDIT : Perhaps it is an Asus P2L97-S ? EDIT2: That is unlikely as the P2L97-S is ATX and already has a PS/2 mouse port
b ) If your board has onboard USB ports (1.1 or 2.0), you might as well use a USB mouse. There is nothing to be gained from a compatibility or functionality perspective by adding a card with a USB controller and ports and also an integrated USB to Ps/2 converter .
c) Unless your board has a PS/2 mouse emulation over USB option in the BIOS, you will need to use a rather big (conventional memory footprint wise) TSR program to allow the mouse to work in DOS, this will likely be problematic if you intend to run conventional memory hungry programs. Additionally any PS/2 mouse emulation over USB option your BIOS may have will likely only work with your motherboard's integrated USB ports
d) If you intend to only use a mouse under Windows, you will be better off with a native USB mouse, again preferably on one of the motherboard's integrated USB ports
Reply 5 of 17, by Jo22
Windows 95 never was meant to be used with USB, especially not USB 2.0.
The OEM releases "with USB support" had USB 1.0 support that was flaky, at best.
It was useful for USB keyboards and mice only, maybe printers, too.
Anyway, I'm just saying. Experiments are cool, but please don't expect too much.
Even Windows 98FE wasn't really USB compatible/capable. It was Windows 98SE with WDM driver model that got USB functioning in a kind of stable way.
Reply 6 of 17, by red-ray
cookertron wrote on 2023-01-15, 01:35:
You should specify exactly which W95 build you have.
darry wrote on 2023-01-15, 03:01:
b ) There is nothing to be gained from a compatibility or functionality perspective by adding a card with a USB controller and ports and also an integrated USB to Ps/2 converter .
Yes there is when you use a KVM which only has PS2 ports.
Reply 7 of 17, by cookertron
First, what is an "Asus P97-S" ? I can't find any reference to that anywhere, so I presume that there's a typo somewhere. Can yo […]
Hi Vogons, […]
Hi Vogons,
Thank you
Anthony
Sorry the board is a Asus SP97-V. It has a USB PS2 Infrared header on board but as I don't have an ATX form card (they don't seem to be a think outside of the US) I thought the USB to PS2 PCI card would be the best option. It's recognise by windows 95 but there doesn't appear to drivers for it.
Reply 8 of 17, by cookertron
red-ray wrote on 2023-01-15, 08:14:
You should specify exactly which W95 build you have. […]
You're right I should have but I only installed it yesterday and I'm not even sure how to find out which version it is. I'll Google that solution and report back.
Reply 9 of 17, by red-ray
cookertron wrote on 2023-01-15, 08:28:
If you run my SIV32L it will tell you, further why did you install W95 rather than W98SE as with W98SE I expect getting USB to work will be far easier.
Why don't you make up a cable and connect the PS2 mouse directly to the USB_IR_MOUSE header?
Reply 10 of 17, by mmx_91
cookertron wrote on 2023-01-15, 08:25:
Check for PCchips and 'compatible' boards that have the same ATX form card you should be able to get this component easier. I remember having a Matsonic MS6260S that had it (Pcchips M579) Good luck!
Reply 11 of 17, by cookertron
red-ray wrote on 2023-01-15, 08:35:
You're right I should have but I only installed it yesterday and I'm not even sure how to do find out which version it is.
It's windows 4.00.950
I already have a windows 98 machine.
Make up a cable!? 😂
Reply 12 of 17, by cookertron
I'm going to re-install Windows 95 using OSR2.1 version and see if that gets things moving. Fingers crossed!
Reply 14 of 17, by darry
I should have specified "as opposed to plugging in a PS/2 to USB adapter into an existing integrated USB port".
I happen to using a PS/2 KVM along with such adapters .
Reply 15 of 17, by red-ray
darry wrote on 2023-01-15, 13:26:
This is still at best misleading as the SP97 integrated USB ports need an optional header which as op needs to add a PS/2 port he clearly does not have.
file.php?id=155056
Reply 16 of 17, by Sphere478
The pinouts on those cards and headers can sometimes vary. I have learned the hard way the best way to probe them is with a scope because hooking them up wrong can fry the ps2/usb controller
Sphere's PCB projects.
Reply 17 of 17, by darry
red-ray wrote on 2023-01-15, 13:47:
This is still at best misleading as the SP97 integrated USB ports need an optional header which as op needs to add a PS/2 port h […]
file.php?id=155056
Please keep in mind that I was explaining/detailing my line of thought prior to OP confirming that there were no USB ports on the board (only headers). That line of thinking only made sense if there were directly usable USB ports on the motherboard, which OP confirmed was not the case in a later post. I also mentioned this in point b) from the very beginning (you only quoted part of it):
That all being said, I think we will likely all agree that since a PS/2 mouse port header is present on the motherboard (which we now know), it makes the most sense to source (and modify, if necessary) a mini DIN connector and use that on a Windows 95 machine.
