Allround system (updated)
Reply 40 of 51, by leileilol
Anonymous Coward wrote:
I think you're confusing the am5x86 and the am486.
nope, it's specified right on the chip label. There's no jumpers or bios setting to toggle the write mode for this cpu.
Reply 41 of 51, by Anonymous Coward
Do you have a picture of this chip? I've never seen one like that before. The only thing I see on my 5x86 chips are the indicators for 55 or 85 degree tolerance.
Also, this page talks about the WT/WB modes of the 5x86:
http://web.inter.nl.net/hcc/J.Steunebrink/amd5x86.htm
Reply 42 of 51, by Amigaz
Just got another ECS UM4980 motherboard...this time it's rev 2.1 instead of 1.0 which is in this machine.
Sadly they seem to have removed the option to set system speed in steps of 1/16 😖
And there's no built in voltage regulator for 3-5volt CPU voltage...you gave to mount a special voltage regulator board which is what I have on my ECS UM8810 board.
My retro computer stuff: https://lychee.jjserver.net/#16136303902327
Reply 43 of 51, by Amigaz
Have retired this machine.
Mobo is for sale if anyone is interested.
Will be selling it on Ebay in circa two weeks if I don't get a "bite" from someone here
Reply 44 of 51, by Anonymous Coward
Those are good boards. I gave away one just like it last week. Do you think they're worth much on ebay?
Reply 45 of 51, by Amigaz
Was it a rev 1.0 like mine? only rev 1.0 have the variable slow down feature
I should be "valuable" to those who appreciate the slow down feature of this rare revision....I will have to advertise this feature when I sell it
Reply 46 of 51, by PowerPie5000
That motherboard looks identical to mine except i have 2 x 72-pin simm slots next to the row of 30-pin simm slots.... apart from that it is pretty much identical!
Mine is now running:
Amd 486 DX4-100mhz.
32mb FPM 60ns RAM (2 x 16mb 72-pin simms).
1.6gb Fujitsu IDE hard drive.
8x Sony CD drive.
1mb Cirrus VLB graphics.
Winbond VLB I/O card (IDE, floppy and com ports etc...).
Sound Blaster Pro 2 (CT1600).
Windows 95/Dos 6.22
I could never identify the motherboard but now i'm guessiing it may be a later revision of yours with 2 72-pin simm slots added?
Reply 47 of 51, by Amigaz
PowerPie5000 wrote:
That motherboard looks identical to mine except i have 2 x 72-pin simm slots next to the row of 30-pin simm slots.... apart from […]
Amd 486 DX4-100mhz.
8x Sony CD drive.
Windows 95/Dos 6.22
Are you sure it's an UM4890? is the model # typed on the board?
Reply 48 of 51, by PowerPie5000
Amd 486 DX4-100mhz.
8x Sony CD drive.
Windows 95/Dos 6.22
This diagram looks like mine which also looks quite similar to yours: http://artofhacking.com/th99/m/A-B/33259.htm
Here is a photo of the exact same board i have: http://farm1.static.flickr.com/236/455596555_ … 9e8c7bc.jpg?v=0
The Bios string is: 02/28/95-UMC-498GP-2C4X6U01-00 (Award Modular Bios v4.50G) and it has the model number "JK-042A" printed on the board.
Reply 50 of 51, by retro games 100
I'm curious, why did you retire this UM4980 mobo? Did you find that although it had the 1/16 BIOS speed stepping functionality, using it wasn't as effective as a real 386? I just spotted a UM4980 mobo on ebay, but it might be the version without the 1/16 BIOS speed stepping functionality. It's here.
Also, on a different topic, while browsing ebay I was quite shocked that the seller BlackmoreIT managed to sell an old Viglen 486 mobo for £100! That's over $US 160. I have one of these mobos, and its Dallas RTC is soldered on to it, and also I could not get it to POST. It's here.
Reply 51 of 51, by Amigaz
As a 486 system it wasn't very "exiting"
I wanted something more "solid" and of better quality so I built three 486 machines based on Eisa motherboards made by Everex and ECS.
Going to sell this UM4890 mobo someday, it's only the rev 1.0 that has this "speed" function in the BIOS
