First post, by Vlady
I'm having a slight problem with Fantasy Empires. I'm new to Dosbox, just fyi, so this may be an easy fix. I've searched around the forums and found nothing however.
If I run this game without a frontend (I've tried D-Fend and Dos Box Game Loader) it runs no prob. I just mount the directory that contains the game files as C and run the .exe file. I dont do anything fancy with settings.
However, when I use the front ends mentioned the game loads with 2 mouse pointers on the screen. The normal one (a hand graphic) and a second which I believe is the Windows pointer. Both move at different speeds and it's really annoying. I've messed with all kinds of settings in the game profile but cant figure this out. I'd rather use the front ends for running dosbox. Can anyone help me?
Dosbox v .65
Asus MB (cant remember model) w/ onboard sound
AMD Althlon 64 3200+
EVGA 7800GT 256MB
XP sp2 fully patched
