Reply 580 of 591, by Sghettikus
Thanks
Reply 581 of 591, by Sghettikus
ok so it only works when i have an actual burned cd in and not an iso
Reply 582 of 591, by myne
Eh?
Weird. I haven't even had a drive in 20 years.
I used daemon tools.
I built:
Reply 583 of 591, by BEEN_Nath_58
myne wrote on 2026-05-09, 13:27:
Eh?
Maybe they have drive letter issue? real drive letter is queried first
Reply 584 of 591, by Sghettikus
I use power iso so maybe that's the issue and the CD drive letter it's looking for is f
Reply 585 of 591, by BEEN_Nath_58
Sghettikus wrote on 2026-05-09, 13:57:
If you have both drive and power iso drive at the same time, one thing you could do is swap the drive letters, so that the power iso one is the first
Reply 586 of 591, by Sghettikus
power iso was the problem cuz i installed daemon tools lite and mounted it and now it worked
Reply 587 of 591, by Sghettikus
also theres no music
Reply 588 of 591, by BEEN_Nath_58
Sghettikus wrote on 2026-05-09, 15:14:
You converted into an ISO. ISO can't contain music. Consider using bin/cue, mdd/mds, ccd/img, etc
Reply 589 of 591, by Sghettikus
i should have said that the files were bin/cue files, that is my fault i didn't know the terms
Reply 590 of 591, by BEEN_Nath_58
Sghettikus wrote on 2026-05-09, 17:52:
Mech2 has a limitation that it only reads CD audio from the first cd drive only. If you have multiple drives, real or virtual, that could be a problem if you are not on the first drive.
Considering that you correctly converted to bin/cue, and the music is playable in Windows Media Player, the only other choice I see is to rip the music to your local storage, let me know if the previous two ideas don't work
Reply 591 of 591, by Jerad2142
BEEN_Nath_58 wrote on 2024-10-31, 08:58:
You can rip the CD audio in ogg format, in the following names "track02.ogg", "track03.ogg"... "trackmn.ogg", starting with 02, […]
Khoidoan1@hotmail.co wrote on 2024-10-30, 23:30:
I've got the game (MW2 mercenaries Titanium trilogy) running almost perfect thanks to the MW2 installer. The only things that ar […]
I've got the game (MW2 mercenaries Titanium trilogy) running almost perfect thanks to the MW2 installer. The only things that are missing is that the music does not play (even with the CD with audio tracks in the drive) and there appears to be a memory leak.
Basically the game's memory usage will continue to rise until it hits about 1.6 GB if you haven't put in a 4GB patch. Or it hits 3.6 GB if you have put in a 4GB patch. You'll know that the memory leak has completed when the HUD dies and multiple enemies disappear from the map.
You can rip the CD audio in ogg format, in the following names "track02.ogg", "track03.ogg"... "trackmn.ogg", starting with 02, and put the files in a "Music" folder beside the game folder. Subsequently, change the DxWnd configuration for the game in the "Cdaudio" tab from "Play from CD" to "Use audio files".
The memory leak is a real issue, if you are on Windows 10, you can try your luck enabling shim:EmulateHeap in the "Tweaks" tab of DxWnd or alternatively patch:HeapLeak or patch:SafeHeap.
If neither of it works, you can try the "MechVM" installation of the game, that will only use DxWnd to fix the initial mission crash and all other fixes will be from MechVM
Thanks so much for this info, I've always wanted to play through the titanium version of the game but the shortened music kinda ruined it for me, but with this knowledge I was able to take the Dos/WIn95 version of the game's music and swap it into Titanium.
One quick question, is there a fix for when missiles miss their target and slow way down? Its really noticable with the Arrow IV's but I've seen normal missiles doing it as well.
