First post, by Great Hierophant
- l33t
I have a Voodoo 5 5500 MAC PCI that has a VGA port with a non-functioning (or extremely weak) green signal. Its DVI port outputs just fine, so I think it is likely that there is a fault somewhere in the green signal, such as a dead resistor or capacitator. Can anyone point me in the direction of instructions to fix the problem?
