Glide Trouble! :(
First post, by uglyhead
Hello,
Whenever I start XA3DFX.exe or 3dFX.bat, I get the typical DOSBox loading screen, then the screen freezes on that, and sound continues, but nothing else happens. I can get out of this problem by Alt-Tabbing, Task Managar, or Clicking X if I am using a Window (I have tried it both fullscreen and windowed.)
I am using Daum's Glide-supporting .72 version, and I have copied its Glidex2.ovl into /Extreme, overwriting the original.
I have also installed Zeckensack's Glide Wrapper on my PC.
I am using Windows XP 32 bit.
What's going wrong here please? Thank you!
Reply 1 of 3, by wd
Rank DOSBox Author
DOSBox Author
Ask on daum's forums.
Reply 2 of 3, by DosFreak
You'd be better off using Gulikoza's build of DOSBox since he his the maintainer of the Glide patch for DOSBox. He's also alot more available for questions than ykhwong is.
Make your games work offline
Reply 3 of 3, by 3Dman
Hello! I am wondering, uglyhead, did you get solution to Extreme Assault? I am trying to get 3Dfx version running with the same result. I use Gulikozas build. I got 3Dfx logo and then nothing... Did you find help with this, can you share please? 😀 Thanks !
