First post, by Aspie_Boi
Carmageddon CD-ROM full original UK version.
Here's what I've tried:
Virtual PC 4.36 [Win95 (4.00.950) Guest OS]: Both DOS & Win95 versions work flawlessly but slowly in SVGA & VGA modes.
In Windows with VDMSound: Dos version works fine in standard VGA mode. In SVGA mode (using carma.exe -hires) and nolfb the game hard locks my PC. The Windows 95 version loads fine in both VGA and SVGA modes but occasionally gives me C++ runtime errors. I can't give you any details as I haven't seen any in a while but I will post details when I recive another.
Since the vga dos version is the most stable under standard Windows with VDMSound that's what I've been using, but I'd like the SVGA version to run stably and with speed (which is an issue under VPC).
I had a look at the Window Application Compatibilty Toolkit 2.6, but it didn't have an entry for the game, and I'm baffled as to where to begin with the whole thing in general.
Anyhow here's hoping someone will have some ideas.
Windows XP Pro SP1
VDMSound 2.0.4 update 1
